ESP Thermal considerations
Re: ESP Thermal considerations
I would like to add that it happened in a few other EV boards. And the current usually drops to around 100-150mA. In one of them manual reset helped.
This is all quite unusual. I'm not denying this is happening to you, it's just that noone else has reported this kind of systemic problem. I have three more questionsI would like to add that it happened in a few other EV boards. And the current usually drops to around 100-150mA. In one of them manual reset helped.
- Were they all ESP32 Things, or some other ESP32 boards as well?
- Can you tell anything else about the code you're running on these boards?
- If you run an unmodified (except for Wi-Fi SSID/password) example from ESP-IDF or Arduino for ESP32, can you reproduce this?
Hi, what about your power supply? Does it look stable? Can you look at it with an Oscilloscope? (With a 10 mohm series resistor between your power source and the ESP32 it would be even better!). Perhaps the consumption pattern could tell us something about what's happening to you.I would like to add that it happened in a few other EV boards. And the current usually drops to around 100-150mA. In one of them manual reset helped.
- Some were ESP32 things and some were other boards.This is all quite unusual. I'm not denying this is happening to you, it's just that noone else has reported this kind of systemic problem. I have three more questionsI would like to add that it happened in a few other EV boards. And the current usually drops to around 100-150mA. In one of them manual reset helped.
- It is an iperf example from ESP-IDF with wifi SSID modified.
- It happens to be my code
Hi,Hi, what about your power supply? Does it look stable? Can you look at it with an Oscilloscope? (With a 10 mohm series resistor between your power source and the ESP32 it would be even better!). Perhaps the consumption pattern could tell us something about what's happening to you.I would like to add that it happened in a few other EV boards. And the current usually drops to around 100-150mA. In one of them manual reset helped.
It is a bit noisy with small ripples on 3.3V while transmitting. Why is the 10mOhm resistor needed?
The goal was to pinpoint the source of the noise. Whether it's a noisy power supply or the drops are simply because of [acceptable] lack of regulation. I was looking for something dramatic that might cause a very wrong behaviour in the module. I guess that's ruled out.Hi,
Is the power consumption the same when the FTDI cable is not connected?
I would suspect an incorrectly wired FTDI cable or maybe a 5v serial adapter could cause heating in the esp32.
Users browsing this forum: PerplexityBot and 3 guests
