Re: I²C clock problem
Posted: Thu Jan 24, 2019 10:50 pm
Have you enabled Power Management? The DFS might be the cause of the issue as your i2c_master_read_slave doesnt include pm locks.
Hi,Have you enabled Power Management? The DFS might be the cause of the issue as your i2c_master_read_slave doesnt include pm locks.
void Initialize_pm_lock()
esp_err_t ret;
if((ret = esp_pm_lock_create(ESP_PM_APB_FREQ_MAX, 1, "CPU_FREQ_MAX", &pm_lock_handle)) != ESP_OK) {
printf("pm config error %s\n", \
ret == ESP_ERR_INVALID_ARG ? "ESP_ERR_INVALID_ARG" : \
(ret == ESP_ERR_NOT_SUPPORTED ? "ESP_ERR_NOT_SUPPORTED" :\
"ESP_ERR_NO_MEM"));
esp_err_t i2c_master_read_slave(i2c_port_t i2c_num, uint8_t slave_address, uint8_t registerAddress, uint8_t* data_rd, size_t size)
i2c_cmd_handle_t cmd = i2c_cmd_link_create();
i2c_master_start(cmd);
i2c_master_write_byte(cmd, slave_address << 1 | I2C_MASTER_WRITE, I2C_ACK_CHECK_EN);
i2c_master_write_byte(cmd, registerAddress, I2C_ACK_CHECK_EN);
i2c_master_write_byte(cmd, slave_address << 1 | I2C_READ_BIT, I2C_ACK_CHECK_EN);
if (size > 1) {
i2c_master_read(cmd, data_rd, size - 1, I2C_ACK_VAL);
i2c_master_read_byte(cmd, data_rd + size - 1, I2C_NACK_VAL);
i2c_master_stop(cmd);
esp_pm_lock_acquire(pm_lock_handle);
esp_err_t ret = i2c_master_cmd_begin(i2c_num, cmd, 100000 / portTICK_RATE_MS);
esp_pm_lock_release(pm_lock_handle);
i2c_cmd_link_delete(cmd);
if(ret != ESP_OK)
ESP_LOGE(TAG, "i2c error: %s", esp_err_to_name(ret));
return ret;
The last recordings where made using the modefied i2c_master_clear_bus function. Here is a recording using the orginal master branch:Hi,Have you enabled Power Management? The DFS might be the cause of the issue as your i2c_master_read_slave doesnt include pm locks.
Thanks for your reply!
I have tried your suggestion, both using pm locks and disabled DFS in menuconfig:
The clock looks better now but it still behaves strange and do not communicate with the gauge IC with this frequency.DFS turned on with power locksCode: Select all
void Initialize_pm_lock() { esp_err_t ret; if((ret = esp_pm_lock_create(ESP_PM_APB_FREQ_MAX, 1, "CPU_FREQ_MAX", &pm_lock_handle)) != ESP_OK) { printf("pm config error %s\n", \ ret == ESP_ERR_INVALID_ARG ? "ESP_ERR_INVALID_ARG" : \ (ret == ESP_ERR_NOT_SUPPORTED ? "ESP_ERR_NOT_SUPPORTED" :\ "ESP_ERR_NO_MEM")); } } esp_err_t i2c_master_read_slave(i2c_port_t i2c_num, uint8_t slave_address, uint8_t registerAddress, uint8_t* data_rd, size_t size) { i2c_cmd_handle_t cmd = i2c_cmd_link_create(); i2c_master_start(cmd); i2c_master_write_byte(cmd, slave_address << 1 | I2C_MASTER_WRITE, I2C_ACK_CHECK_EN); i2c_master_write_byte(cmd, registerAddress, I2C_ACK_CHECK_EN); i2c_master_start(cmd); i2c_master_write_byte(cmd, slave_address << 1 | I2C_READ_BIT, I2C_ACK_CHECK_EN); if (size > 1) { i2c_master_read(cmd, data_rd, size - 1, I2C_ACK_VAL); } i2c_master_read_byte(cmd, data_rd + size - 1, I2C_NACK_VAL); i2c_master_stop(cmd); esp_pm_lock_acquire(pm_lock_handle); esp_err_t ret = i2c_master_cmd_begin(i2c_num, cmd, 100000 / portTICK_RATE_MS); esp_pm_lock_release(pm_lock_handle); i2c_cmd_link_delete(cmd); if(ret != ESP_OK) ESP_LOGE(TAG, "i2c error: %s", esp_err_to_name(ret)); return ret; }
DFS turned off and without power locks.
If you disabled DFS, you dont need the locks but Ive found DFS saves quite a bit of power, so its best to leave it on in the future (the PM lock should prevent further scl-messing-up-ness when DFS is turned on). I cant tell without a bit more information on the actual timing of your I2C transaction, but it looks like youre encountering the same issue I had talking to a BQ27621 (another TI battery monitor from the BQ35100 you are using). You should try adding this to right after you initialize I2C master:The last recordings where made using the modefied i2c_master_clear_bus function. Here is a recording using the orginal master branch:Hi,Have you enabled Power Management? The DFS might be the cause of the issue as your i2c_master_read_slave doesnt include pm locks.
#define I2C_MASTER_TRANSACTION_TIMEOUT_MS (10)
i2c_set_timeout(I2C_MASTER_PORT, I2C_APB_CLK_FREQ * I2C_MASTER_TRANSACTION_TIMEOUT_MS / 1000)Thank you for your reply!If you disabled DFS, you dont need the locks but Ive found DFS saves quite a bit of power, so its best to leave it on in the future (the PM lock should prevent further scl-messing-up-ness when DFS is turned on). I cant tell without a bit more information on the actual timing of your I2C transaction, but it looks like youre encountering the same issue I had talking to a BQ27621 (another TI battery monitor from the BQ35100 you are using). You should try adding this to right after you initialize I2C master:The last recordings where made using the modefied i2c_master_clear_bus function. Here is a recording using the orginal master branch:
Details can be found here:Code: Select all
#define I2C_MASTER_TRANSACTION_TIMEOUT_MS (10) ... i2c_set_timeout(I2C_MASTER_PORT, I2C_APB_CLK_FREQ * I2C_MASTER_TRANSACTION_TIMEOUT_MS / 1000)
https://www.esp32.com/viewtopic.php?f=13&t=6203#p37174
Hi dragondgold,@persan666 did you find any solution to the problem? I'm using a bq27441 fuel gauge and I'm experiencing the exact same problem, DFS is disabled and I increased the timeout time, I have no errors, just inconsistent clock when using 400 kHz.
