internet unavailable when connected to AP(Wi-Fi) of ESP32 DevKit,
WiFive
Re: internet unavailable when connected to AP(Wi-Fi) of ESP32 DevKit,
Postby WiFive » Thu Feb 28, 2019 8:52 am
IP4_ADDR(&info.gw, 192, 168, 1, 1);//ESP acts as router, so gw addr will be its own addr
Set this to 0 otherwise your phone will try to send internet traffic there
Ritesh
Contact:
Postby Ritesh » Thu Feb 28, 2019 11:42 am
Hi WiFive,
I have one query like iOS device can get internet connection from ESP32 when it is connected with ESP32 device into AP mode?
Let me correct what I understood is like below
1) iOS device doesn't has any internet connection
2) ESP32 Device is working as AP mode
3) iOS Device is trying to connect with ESP32 device and trying to get internet connection with that
or let me correct if I understood something wrong?
Regards,
Ritesh Prajapati
WiFive
Postby WiFive » Thu Feb 28, 2019 12:23 pm
No it is like
1) iOS device has cellular internet connection
3) iOS Device is trying to connect with ESP32 device and trying to keep internet connection from cellular
Ritesh
Contact:
Postby Ritesh » Thu Feb 28, 2019 1:01 pm
No it is like
Ok. Understood.
Then Internet connection should be remained as it is into iOS phone even if after connecting that iOS device with ESP32 into AP mode.
Regards,
Ritesh Prajapati
jcsbanks
Postby jcsbanks » Wed Feb 10, 2021 4:21 pm
Interesting about the Garmin device. What device is it? Does it prevent hijacking the internet connection on both iOS and Android?
Here's what I have after struggling with this as well. It seems to work for iOS, but not always working in Android.
this is in main() before initializing WiFi:
	tcpip_adapter_init();
		tcpip_adapter_ip_info_t info = {0};
		tcpip_adapter_dns_info_t dns_info = {0};
		IP_ADDR4(&dns_info.ip, 0, 0, 0, 0);
		IP4_ADDR(&info.ip, 192, 168, 4, 1);
		IP4_ADDR(&info.gw, 0, 0, 0, 0);
		IP4_ADDR(&info.netmask, 255, 255, 255, 0);
		ESP_ERROR_CHECK(tcpip_adapter_dhcps_stop(TCPIP_ADAPTER_IF_AP));
		ESP_ERROR_CHECK(tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_AP, &info));
		dhcps_dns_setserver(&(dns_info.ip));
		uint8_t opt_val = 0; // don't supply a dns server via dhcps
		//ESP_ERROR_CHECK(tcpip_adapter_dhcps_option(TCPIP_ADAPTER_OP_SET, TCPIP_ADAPTER_DOMAIN_NAME_SERVER, &opt_val, 1));  // don't supply a dns server via dhcps
		ESP_ERROR_CHECK(tcpip_adapter_dhcps_option(TCPIP_ADAPTER_OP_SET, TCPIP_ADAPTER_ROUTER_SOLICITATION_ADDRESS, &opt_val, 1));  // don't supply a gateway (router) via dhcps option 3
		ESP_ERROR_CHECK(tcpip_adapter_dhcps_start(TCPIP_ADAPTER_IF_AP));
Hope it helps.
Trying either option on ESP IDF 3.3 still results in there being a DNS server on 192.168.4.1, but the gateway on 192.168.4.1 disappears. Android still doesn't use cellular in this case.
jcsbanks
Postby jcsbanks » Wed Feb 10, 2021 8:54 pm
https://github.com/espressif/esp-idf/bl ... er.c?#L355
Since I could only set DNS to 0.0.0.0 and that didn't work for Android I also commented out the 13 lines from the link and then in Windows no IPV4 DNS servers are shown. Gateway also not shown. Not sure it makes any difference though as Android 9 still doesn't want to use cellular when connected to ESP32 WiFi though. Developer options set include "Mobile data always active".
WiFive
Postby WiFive » Wed Feb 10, 2021 10:06 pm
You may want to register your support for this https://github.com/espressif/esp-idf/issues/6522
dynek=
Postby dynek= » Tue Jun 06, 2023 6:12 am
Hey,
Has anyone every succeeded in having both mobile/cellular internet connectivity + ESP32 in AP mode (without Internet) on Android devices?
Looks like the following make it so I can at least access the ESP32, but mobile connectivity is not working anymore:
Cheers
MicroController
Postby MicroController » Tue Jun 06, 2023 9:04 pm
This Q/A suggest that you may be able to do it by disabling DHCP for the respective SSID and removing the gateway IP address in Android's WiFi config. Or by "skipping" Android's prompt when first connecting to the internet-less WiFi. Might give that a try.
Users browsing this forum: Applebot, Bytespider, ChatGPT-User, PetalBot and 3 guests
