ESP IDF: Station + soft-AP (WIFI_MODE_APSTA) There is no working example - why? Where is?
Re: ESP IDF: Station + soft-AP (WIFI_MODE_APSTA) There is no working example - why? Where is?
In follow up to my previous post, adding in a few time delays between tearing down AP and starting STA helped. Also, I turned off nvs_flash for WiFi as I think that was causing the corruption when starting in STA mode.
Here's my menuconfig changes.
[OFF ] Wi-Fi -> WiFi NVS flash
[OFF] Phy ->Store phy calibration data in NVS
I was seeing brownouts earlier in the transition and increased
[2.7v] * ESP32-specific -> Brownout Voltage Level
For debugging
[On] WiFi -> Enable Wifi debug Log
[Verbose] WiFi -> WiFi debug log level
If anyone has seen similar issues when trying to use both WiFi modes, please share if you had any better resolutions.
For debugging
This works well for string parameters.
Tell me, how to properly set the WiFi channel in the Access Point mode?
strncpy((char *)ap_config.ap.password, configDev.apPSK, strlen(configDev.apPSK));Re: ESP IDF: Station + soft-AP (WIFI_MODE_APSTA) There is no working example - why? Where is?
That is... I don't think you understand what that does exactly and why one would use strncpy. Str[n]cpy already stops copies as much bytes as are in configDev.aPSK; to specifically set it as a limit with the strlen parameter does nothing useful. In contrast, if configDev.apPSK is too large, you can overwrite the memory of ap_config and corrupt stuff and make your app crash and your strncpy will do nothing to stop it. Correct method is:This works well for string parameters.Code: Select all
strncpy((char *)ap_config.ap.password, configDev.apPSK, sizeof(ap_config.ap.password));Wrt your question: as the docs indicate, the ap_config.ap struct has a channel member, so it would be
ap_config.ap.channel=4;
pranjal.jamdade
Did any one find a proper solution for accessing both AP and STA mode ? Once AP mode is getting after receving SSID+PASS , i am facing issue for station mode.
If any one could suggest please help me out.
Thanks in advance
Thanks in advance
Is your issue has been resolved or still looking for solution?Hello,
Thanks in advance
Regards,
Ritesh Prajapati
Ritesh Prajapati
pranjal.jamdade
Hello ,
Still Looking for Proper Solution for it.
Thanks & Regards
Pranjal
Thanks & Regards
Pranjal
Any luck for working or still looking for solution. Let me know if need any help from my side.Hello ,
Thanks & Regards
Pranjal
Regards,
Ritesh Prajapati
Ritesh Prajapati
monkeyinapocket
i'm also looking for a good solution, it would be great if you could just stop "offering your help" and provide a simple example instead because you said it would work....
With the current exmaples it is/was not possible for me to provide a SoftAP (that worked) and also to connect to a available WiFi.
It would be awesome if you could just share your proposed working snippets.
Thanks in advance.
Best Thomas
Thanks in advance.
Best Thomas
HelloHi,
Thanks in advance.
Best Thomas
Can you please share me example which you are trying and facing issues at your end?
so that i will look it at my end and help for the same.
Regards,
Ritesh Prajapati
Ritesh Prajapati
monkeyinapocket
Sorry, it took me some time to prepare the example. The following code snipped should be able to create an AP an also connect to a available WiFi - it would be great if you can tell me, what i'm doing wrong.
Thanks in advance,
Best Monkeyinapocket
Thanks in advance,
#include <cstring>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT BIT1
static const char *TAG = "test";
static EventGroupHandle_t s_wifi_event_group;
static wifi_config_t wifi_config;
static void wifi_event_handler(void* arg, esp_event_base_t event_base,
int32_t event_id, void* event_data)
if (event_id == WIFI_EVENT_AP_STACONNECTED) {
wifi_event_ap_staconnected_t* event = (wifi_event_ap_staconnected_t*) event_data;
} else if (event_id == WIFI_EVENT_AP_STADISCONNECTED) {
wifi_event_ap_stadisconnected_t* event = (wifi_event_ap_stadisconnected_t*) event_data;
void wifi_init_softap(void)
esp_netif_create_default_wifi_ap();
ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
ESP_EVENT_ANY_ID,
&wifi_event_handler,
NULL,
NULL));
const char* ssid = "ESPTest";
const char* pw = "testtest";
std::strcpy(reinterpret_cast<char *>(wifi_config.ap.ssid), ssid);
std::strcpy(reinterpret_cast<char *>(wifi_config.ap.password), pw);
wifi_config.ap.ssid_len = static_cast<uint8_t>(strlen(ssid));
wifi_config.ap.channel = 1;
wifi_config.ap.max_connection = 1;
wifi_config.ap.authmode = WIFI_AUTH_WPA_WPA2_PSK;
if (strlen(pw) == 0) {
wifi_config.ap.authmode = WIFI_AUTH_OPEN;
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA));
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
static int s_retry_num = 0;
static int maxRetry = 5;
static void sta_event_handler(void* arg, esp_event_base_t event_base,
if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
esp_wifi_connect();
} else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
if (s_retry_num < maxRetry) {
esp_wifi_connect();
s_retry_num++;
ESP_LOGI(TAG, "retry to connect to the AP");
xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
ESP_LOGI(TAG,"connect to the AP fail");
} else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
ESP_LOGI(TAG, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
s_retry_num = 0;
xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
void wifi_init_sta(void)
s_wifi_event_group = xEventGroupCreate();
esp_netif_create_default_wifi_sta();
esp_event_handler_instance_t instance_any_id;
esp_event_handler_instance_t instance_got_ip;
ESP_EVENT_ANY_ID,
&sta_event_handler,
NULL,
&instance_any_id));
ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
IP_EVENT_STA_GOT_IP,
&sta_event_handler,
NULL,
&instance_got_ip));
const char* ssid = "TestSSID";
std::strcpy(reinterpret_cast<char *>(wifi_config.sta.ssid), ssid);
std::strcpy(reinterpret_cast<char *>(wifi_config.sta.password), pw);
wifi_config.sta.threshold.authmode = WIFI_AUTH_WPA2_PSK;
wifi_config.sta.channel = 2;
wifi_config.sta.pmf_cfg.capable = true;
wifi_config.sta.pmf_cfg.required = false;
ESP_LOGI(TAG, "Test -> %s %s.", wifi_config.sta.ssid, wifi_config.sta.password);
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
//ESP_ERROR_CHECK(esp_wifi_start());
ESP_LOGI(TAG, "wifi_init_sta finished.");
/* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
* number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
pdFALSE,
pdFALSE,
portMAX_DELAY);
/* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
* happened. */
if (bits & WIFI_CONNECTED_BIT) {
ESP_LOGI(TAG, "connected to ap");
} else if (bits & WIFI_FAIL_BIT) {
ESP_LOGI(TAG, "Failed to connect");
ESP_LOGE(TAG, "UNEXPECTED EVENT");
/* The event will not be processed after unregister */
ESP_ERROR_CHECK(esp_event_handler_instance_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, instance_got_ip));
ESP_ERROR_CHECK(esp_event_handler_instance_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, instance_any_id));
vEventGroupDelete(s_wifi_event_group);
extern "C" void app_main(void)
//Initialize NVS
ESP_ERROR_CHECK(ret);
wifi_init_softap();
vTaskDelay(10000);
wifi_init_sta();
