Hi ESP_Angus,
At first i think it's good the way it is.
From 4.1us to 3us ( -Og compiler optimization ).
From 4.1us to 1,9 us ( -Os compiler optimization ).
Thank's for the help.
Integer division performance ????
Re: Integer division performance ????
Hi ESP_Angus,
Below follows what i'm doing.
Called only in startup.
Called every time you want to send data through dma.
This configuration through my tests is working.
Do you think this can cause any type of problems ?
My next step will be to implement interrupt.
Can it generate any problem ?
Thank's for your help.
static DMA_ATTR uint32_t buf_a[ 15360 ];
static DMA_ATTR lldesc_t dma_desc_buf_a[ 16 ];
static void init_dma_descriptors_a( )
for ( uint32_t i = 0 ; i < descriptor_size ; i++ ) // descriptor_size = 16
dma_desc_buf_a[i].size = 4092;
dma_desc_buf_a[i].length = 0;
dma_desc_buf_a[i].offset = 0;
dma_desc_buf_a[i].sosf = 0;
dma_desc_buf_a[i].eof = 1; // indicate that are the last node of linked list.
dma_desc_buf_a[i].owner = 1; // the allowed operator is the DMA controller.
dma_desc_buf_a[i].buf = (uint8_t*) ( ( &buf_a[0] ) + ( 1023 * i ) );
if ( i == descriptor_size - 1 )
dma_desc_buf_a[i].qe.stqe_next = ( lldesc_t* ) NULL;
else
dma_desc_buf_a[i].qe.stqe_next = ( lldesc_t* ) &dma_desc_buf_a[i+1];
Here i eliminated this instruction in all last transfer node:
dma_desc_buf_a[ i ].qe.stqe_next = ( lldesc_t* ) NULL;
I am only using:
dma_desc_buf_a[ i ].eof = 1;
static inline int fill_dma_descriptor_a ( uint32_t len ) // uint32_t len in bytes. When len = 15360 bytes the function takes 3 us( -Og compiler optimization ). 1,9 us( -Os compiler optimization ).
uint32_t length;
if ( len > 15360 ) return -1;
if ( len == 0 ) return -2;
length = 4 * len; // ( 4 * len ) = converte de byte(8 bits) para word(32bits).
if ( length <= 4092 ) // Only need one single descriptor.
dma_desc_buf_a[0].length = length;
dma_desc_buf_a[0].eof = 1; // indicate that are the last node of linked list.
return 1;
// if ( length > 4092 ) // Need more that a single descriptor.
uint32_t fullBufferNum;
fullBufferNum = (uint32_t) length / 4092;
uint32_t remainderBufferNum;
remainderBufferNum = ( length % 4092 );
for ( uint32_t i = 0 ; i < fullBufferNum ; i++ )
dma_desc_buf_a[i].length = 4092;
dma_desc_buf_a[i].eof = 0; // indicate that are not the last node of linked list.
if ( remainderBufferNum == 0 ) // Remainder of division are 0. Don't need to allocate more one descriptor.
dma_desc_buf_a[ fullBufferNum - 1 ].eof = 1; // indicate that are the last node of linked list.
return 2;
else // Need to allocate (statically) 1 more descriptor.
dma_desc_buf_a[fullBufferNum].length = remainderBufferNum;
dma_desc_buf_a[fullBufferNum].eof = 1; // indicate that are the last node of linked list.
return 3;
Looks fine to me. Of course I can't debug your driver for you, maybe something will need changing here.This configuration through my tests is working.
You're asking me if code you haven't written yet might have a problem?My next step will be to implement interrupt.
Hi ESP_Angus,
"You're asking me if code you haven't written yet might have a problem?"
I would like to know if i need or i dont need both "instructions" at the same time on last node of linked list:
dma_desc_buf_a[ last node ].eof = 1;
dma_desc_buf_a[ last node ].qe.stqe_next = ( lldesc_t* ) NULL;
I am only using:
In my first stage of driver development i was initializing all fields from my linked list, ie: all lldesc_t fields from each node,
which took a long time to fill.
So i optimized my code and i wonder if this way is ok.
The last stage of my driver development are to implement interrupt and 2 buffer sync plus tearing sync, which i think will give me a lot of headache.
I am only using:
Hi Baldhead,
Right, sorry I missed that. I checked with the peripheral teams, both fields need to be set: EOF=1 causes an EOF interrupt to be triggered when the descriptor is reached, but the DMA operation will continue until it reaches a field where the next descriptor pointer is NULL.I would like to know if i need or i dont need both "instructions" at the same time on last node of linked list:
Hi ESP_Angus,
"Right, sorry I missed that. I checked with the peripheral teams, both fields need to be set: EOF=1 causes an EOF interrupt to be triggered when the descriptor is reached, but the DMA operation will continue until it reaches a field where the next descriptor pointer is NULL."
Strange.
For me it's working with only this "instruction": dma_desc_buf_a[ last node ].eof = 1.
However i am not currently using interrupt, i am using polling.
I am using polling for testing purposes only.
Thank's.
Strange.
Thank's.
Users browsing this forum: ChatGPT-User, Google [Bot] and 1 guest
