Is it possible to have data corruption just after a soft restart?
PeterR
Re: Is it possible to have data corruption just after a soft restart?
Postby PeterR » Mon Aug 24, 2020 4:06 pm
There are two issues, overflow and errata corruptions. Overflow recovery tends to increase errata corruptions. Did for me anyway.
If you read the posts then yes, ESP have a patch to IDF 4.1 which you will find via a link to my posts. The patch may also have been released.
There is actually a third issue in that something in IDF land is 'causing' the overflow by blocking for extensive periods (2mS). Perhaps that's me but fairly sure its Ethernet. So corruption/drop out might be higher for you than the electrical plumbing environment might suggests.
As discussed I get the data again so not a big issue for me.
Users browsing this forum: Bing [Bot], Qwantbot and 1 guest
