ESP32-S3 USB OTG - USB Hub support?
Re: ESP32-S3 USB OTG - USB Hub support?
Hi everyone,
Seeking any news regarding support for USB hub.
We are developing a product where it is required. The limitations mentioned in earlier posts are not a showstopper for us.
But we would like to see the beta branch for public testing mentioned by tore-espressif. It would certainly help and be interesting to explore.
Any news on that one?
Looking forward for a beta release.
I have experience developing a USB stack for MSX computers via a CH376 in low-level mode. Will contribute my findings and use it in a new ESP32 S3 project.
Btw. in my previous project I had a 8 port hub connected with various devices. But the user could choose which ones it wanted to communicate with to go around the I/O limits of the CH376.
Okay, little update, I managed to connect to a USB HUB, retrieve the Hub descriptor, power-on and check which ports have devices attached, and reset each and every device.
From that moment on I'm a bit stuck because messages send/from a reset hub port attached device are not being returned. Per specification after RESET you can continue to communicate to EP0 on address 1 where the hub will forward the communication to EP0 of the connected device. Instead I still wrongly get (cached?) answers from the Hub.
One of those messages would be the SET_ADDRESS command to tell the device (and hub) that from that moment on it is at for example address 2.
After this you can communicate to address 1 for hub related messages and address 2 to N for the other devices messages.
2. Small Receive FIFO - 512 bytes: 512 bytes is borderline enough for one streaming (high-bandwidth) FullSpeed device. It will not be possible to stream from 2 USB camera at the same time on S2/3 (at reasonable definition of the video).
I am trying to read data from a isochronous device, the InfiRay TS2+ thermal camera.
It uses a MPS of 524 instead of 512, which is 12 bytes too short.
that seems to be [UVC header] + [256 pixels per line * 2 byte]
My question:
Its this limit of 512 a physical limitation, where there is no way to work around?
Or might it be possible with a hack to throw away 12 bytes of every transfer.
I would be even happy with receiving 512 byte, throwing away the last 6 pixels (12 byte).
Best regards
im not sure i am the one who should post this, but i believe that USB hub support is added in master now.
And bu USB hub support i mean we can connect usb hub to esp32S2/S3/P4 and USB host API should access devices connected to hub.
Good job espressif
Good job espressif
tore-espressif
- Espressif staff
Hello everyone interested in USB HUBs!
First of all, I'm sorry for the misinformation about the beta branch. After internal discussion we decided to wait and provide a stable HUB support. This is now available in esp-idf master branch!
Since ESPs are embedded systems there are some notable limitations (I mentioned some of them in previous posts)
* ESP32-S2/S3 has 8 channels, this practically means 1 HUB + 2 devices active at the same time. P4 has 16 channels
* Low-Speed devices through HUB do not work yet
* More in official docs (already merged internally, should be public within days)
The physical limitation is 1024 bytes for all transfers. Maximum for RX is 600 when you select USB_HOST_HW_BUFFER_BIAS_IN in menuconfigIts this limit of 512 a physical limitation, where there is no way to work around?
