Need Help regarding Netconn Memory Leak Issue
Ritesh
Contact:
Re: Need Help regarding Netconn Memory Leak Issue
Postby Ritesh » Wed Dec 06, 2017 5:28 pm
Hi Pratik,
Thanks for posting the code and the log. It's not clear to me from the log that you have a memory leak. If I look at the same log line in your code each time around the loop, there's no long-term trend of less free RAM:
I (23662) main: system_get_free_heap_size after accept  =230864
I (24452) main: system_get_free_heap_size after accept  =230648
I (25592) main: system_get_free_heap_size after accept  =230440
I (879372) main: system_get_free_heap_size after accept  =229896
I (892582) main: system_get_free_heap_size after accept  =229352
I (925662) main: system_get_free_heap_size after accept  =230524
I (925802) main: system_get_free_heap_size after accept  =230872
In fact, the final log line shows more free heap (230872) than the initial line (230864).
This kind of minor variation over time is due to the TCP/IP & WiFi library activity. Some of it may be explained by TCP sockets in the TIME_WAIT state, as I mentioned above, but the WiFi library may also allocate temporary buffers for various uses.
If you see a long term trend of free memory reducing, that is a memory leak.
Ok. Yes.we can say it as short term memory leak which is going to free after sometime.
I think Espressif Systems has fixed that memory leak issue from LWIP netconn code and also released it under master tree.
Regards,
Ritesh Prajapati
Users browsing this forum: Bing [Bot], Qwantbot and 1 guest
