Thank you very much
I will tried up as soon as possible I have one humidity sensor with RS485 and im not able to run it up
ESP32 RS485driver hardwareserial ModbusMaster
Re: ESP32 RS485driver hardwareserial ModbusMaster
hi would you be able to share your code, an old one i know but encountering the same issue
I know it has been a few weeks, but I ran into similar problems, solved them and would like to share. I use a MAX-3485. Basically a 485 but for 3.3v instead of 5v. I couldn't get anyting to work using standard libraries. I used one of the many hardware examples in wich the DE and /RE are connected. DriverEnable is active high, ReceiverEnable is active low. So, why not use one GPIO and use that as a toggle between send and receive, right? After hours of debugging and hooking up a second ESP32/MAX3485 to see what was going on on the RS485 bus, I found that the DE dropped before the transmission of the Modbus frame was complete. My guess is that the library just goes ahead and drops the DE pin after the frame is sent, but at that time the ESP32 still has some data in the transmit buffer. Maybe that is a difference with arduinos, maybe those don't have a transmit buffer?
Anyway: I solved it by modifying my hardware a bit (RE is always low now) and implementing the Modbus protocol myself instead of using a lib. The protocol is quite straightforward. The only thing I had to deal with is reading back my own transmission because the receiver is always on now. But since I know exactly what I sent out, that's not difficult to do.
Modbusmaster works fine with RS485 on a Esp32.
Have a look for the tip and tricks: http://evertdekker.com/?p=1307
You have to set the fucntions preTransmission() and postTransmission() correct, see the above sample
Hi everyone,
I'm trying to do ESP32 communicate with a Freq. Inverter using MAX485 converter. I'm using the library ModbusMaster with Arduino IDE.
I tested a Arduino UNO instead the ESP32 and it worked fine.
With the ESP32 I can only write to the Inverter, but not read.
Did someone foundout the solution to use this library correctly whit ESP32?
This is my code:
This is my code:
#include <ModbusMaster.h>
#define MAX485_RE_NEG 19
ModbusMaster node;
uint8_t deviceID = 1;
uint8_t resultMain;
String c, texto;
String ID, REGISTER, VALUE;
void preTransmission() {
digitalWrite(MAX485_RE_NEG, HIGH);
void postTransmission() {
digitalWrite(MAX485_RE_NEG, LOW);
Serial.begin(9600); // to write modbus
Serial2.begin(4800, SERIAL_8N1, 0, 14); // pino 0 = RX, 14 = TX
pinMode(MAX485_RE_NEG, OUTPUT);
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
while (Serial.available() > 0) {
// Slave ID: ID 0-2 > ID1
// Slave Register: 3-6 > 0005
// Slave Register Value: 7-11 > 1000
c = (char)Serial.read(); // read from serial monitor
if (c == ":") {
else {
texto += c; // texto = texto + c;
ID = texto.substring(2, 3); // pega o número de ID enviado pela serial
REGISTER = texto.substring(3, 7); // pega o endereço da varíavel que recebera a escrita ex: No inv delta ms300 a control word é 2000H
VALUE = texto.substring(7, 11); // pega o valor q será escrito na variável Ex: o valor 0002H coloca o inv em RUN
deviceID = 0;
switch (deviceID) {
// Device ID imaginário - Serve apenas para enviar comandos ao Inversor via RS485
case 0:
node.begin(getInt(ID), Serial2);
resultMain = node.writeSingleRegister(getInt(REGISTER), getInt(VALUE)); // para o inv delta a controlword é 2000H = 8192 decimal value = 0002 run, = 0001 stop
// node.begin(1, mySerial);
// resultMain = node.writeSingleRegister(0x2000, 2);
deviceID = 1;
texto = "";
ID = "";
REGISTER = "";
VALUE = "";
// Rotina que realiza a leitura dos dados pertinenetes ao inversor de frequencia
case 1:
// Modbus ID 1 - Inversor de Frequencia
node.begin(deviceID, Serial2);
node.idle(yield);
delay(200);
resultMain = node.readHoldingRegisters(0x2103 - 1, 4); // Realiza a leitura do registrador 9 ate 14 (0x0E)
delay(200);
if (resultMain == node.ku8MBSuccess) {
Serial.print("ID1 Freq. de Comando ");
Serial.println(node.getResponseBuffer(0x00)); // Apanha o dado alocado na posição 0 do buffer
Serial.print("ID1 Freq. de Saída ");
Serial.println(node.getResponseBuffer(0x01)); // Apanha o dado alocado na posição 1 do buffer
Serial.print("ID1 Tensão do Barramento ");
Serial.println(node.getResponseBuffer(0x03));
Serial.print("ID1MSGN");
Serial.println("Falha de comunicacao");
delay(1000);
deviceID = 1;
delay(45);
// Função que realiza a conversão de um caracter em ASCII para numero inteiro
int getInt(String texto) {
int temp = texto.length() + 1;
char buffer[temp];
texto.toCharArray(buffer, temp);
int num = atoi(buffer);
return num;
}Who is online
Users browsing this forum: Bytespider, ChatGPT-User, DuckDuckGo [Bot] and 2 guests
