ESP32 Bluetooth SPP with bidirectional communication (send and receive)
chegewara
Re: ESP32 Bluetooth SPP with bidirectional communication (send and receive)
Postby chegewara » Mon Nov 18, 2019 10:08 am
If you are flashing this code, i am guessing it is just echoing received data:
    case ESP_SPP_DATA_IND_EVT:
#if (SPP_SHOW_MODE == SPP_SHOW_DATA)
        ESP_LOGI(SPP_TAG, "ESP_SPP_DATA_IND_EVT len=%d handle=%d",
                 param->data_ind.len, param->data_ind.handle);
        if (param->data_ind.len < 1023) {
            snprintf(buf, (size_t)param->data_ind.len, (char *)param->data_ind.data);
            printf("%s\n", buf);
            sprintf(spp_data, "Receined characters: %d\n", param->data_ind.len);
            esp_spp_write(param->write.handle, strlen(spp_data), (uint8_t *)spp_data);
https://docs.espressif.com/projects/esp ... TA_IND_EVT
kluverp
Postby kluverp » Tue Nov 19, 2019 5:40 am
Yes it it is echoing.
But I would expect on calling "esp_spp_write()" that it does not fire the "ESP_SPP_DATA_IND_EVT" event next to the ESP_SPP_WRITE_EVT" event (it does get called once). But only the "ESP_SPP_WRITE_EVT" event.
Do it echos to itself as well.
When I call:
                char *spp_data = "Hello!";
    		esp_spp_write(myHandle, strlen(spp_data), (uint8_t *)spp_data);
It fires the "ESP_SPP_DATA_IND_EVT" event like so:
I (278949) SPP_ACCEPTOR_DEMO: ESP_SPP_DATA_IND_EVT len=1 handle=129
H
a
I (278959) SPP_ACCEPTOR_DEMO: ESP_SPP_DATA_IND_EVT len=1 handle=129
l
l
I (278969) SPP_ACCEPTOR_DEMO: ESP_SPP_DATA_IND_EVT len=1 handle=129
o
I (278979) SPP_ACCEPTOR_DEMO: ESP_SPP_DATA_IND_EVT len=1 handle=129
I did not expect that, nor do I understand why.
senudajayalath
Postby senudajayalath » Wed Mar 02, 2022 8:47 am
You just have to combine receiving and sending, like in this simple example based on example_spp_acceptor_demo.c
I have a few questions on this. Where can I find this `example_spp_acceptor_demo.c` file.
The other question is if I pasted the code you have given to the `main.c` file of `BT_SPP_ACCEPTOR` it did not work. Am I missing something here?
Thanks in advance
Users browsing this forum: Bing [Bot] and 2 guests
