Page 3 of 3
Re: ESP32 not recognized by PC. No COM port problem!
Posted: Thu Oct 24, 2024 1:29 am
by Sprite
Hm, okay. Not sure what that button is for as I can't get it out of the description and the board itself is unknown. You said you used Linux as well? Can you see what happens when you plug it in and enter the command 'sudo dmesg' in the terminal? Feel free to paste the last dozen of lines of that here.
Posted: Wed Oct 30, 2024 11:16 am
by MrSquiz
ESP32-S3-Nano by Waveshare, compatible with Arduino Nano ESP32 board, has problems connecting to Arduino on a computer.
It is not identifying the COM port USB serial device correctly, which I suspect is similar to other ESP32-S3 boards.
Suggested fixes, such as double-press the Reset button, a capacitor across RST (EN on other boards) and GND, and other fixes, either failed or are only partially successful.
[WORKAROUND SOLUTION]
Step 1. Connect the USB C connector of a USB cable to the ESP32-S3 board.
Step 2. S-l-o-w-l-y plug in the USB A connector of the USB cable to the computer.
[EXPLANATION]
When this ESP32-S3 board is powered externally (I run it off a battery for my application) before connecting it to a computer via a USB cable, it works perfectly.
While the Sketch is running, it will connect to the computer, the COM port is correctly identified, Arduino connects and the Serial Monitor works, and a Sketch can be uploaded without errors.
From this I conclude that the problem is a timing issue with the data interface. It is trying to connect before the device is ready for the data connection.
A USB A plug has 4 pins; the outer 2 pins are +5V and GND. The inner 2 pins are the Serial data pins, which are physically further recessed in the plug than the outer pins. Slowly plugging the USB A connector into the computer USB A socket allows the power pins to connect first, and to boot up the ESP32-S3 with enough time before the Serial data pins connect.
Posted: Sat Oct 18, 2025 8:00 am
by jaydenkasuo
If the board still doesn’t show up after installing the FTDI or CP210x drivers, it’s worth checking how the esp32 is powered and initialized. Some boards, especially older dev kits or custom modules, don’t auto-reset when flashing — meaning you might need to manually hold BOOT while tapping EN to enter upload mode.
Also, check the device manager while switching USB ports — Windows sometimes assigns a hidden COM port number if the board was first connected through a different driver stack. Removing old “ghost” serial devices in Device Manager can help too.
If none of that works, try a different cable and plug it into a powered USB hub instead of the front port — some boards pull more startup current than a laptop port can provide, which keeps the esp32 from enumerating properly.
