Hello ESP_Sprite,
thank you for the reply where I agree with most of points you rose. I just want to add that having a testing procedure does not mean to test every component. There are many ways to carry out testing.
The sentence "it must be possible to test every electronic component before mounting into a finished product" is reasonable and correct.
I think a document like "https://www.espressif.com/sites/default ... de__EN.pdf" gives a strong help in handling the ESP32 module. A similar document is aimed to easily deal with basic classified cases. and related exit strategy.
Right now I have again changed the EN pull up resistor (270ohm) and capacitor (120nf) among dozens of combinations (I think it was a push button reset that burned my potmeter) and, again, I'm testing stability. (and no pull-up on IO0)
Furthermore, reading your helpful hints I recognize that a test guide would give a clear/common base among Espressif and Customers.
As per your hints the procedure must be simple, non-invasive and repeatable.
I believe a solution in this direction is possible. It does give immeasurable help.Thank you in advance
Unable to access custom ESP32 over Serial/USB
sergiomarina
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: Bing [Bot], PerplexityBot and 3 guests
- All times are UTC
- Top
- Delete cookies
About Us
Information
