Re: Document Requests
Posted: Fri Sep 28, 2018 1:58 am
You may want to email sales at espressif dot com for that, they can probably help you.
static esp_err_t i2s_apll_calculate_fi2s(int rate, int bits_per_sample, int *sdm0, int *sdm1, int *sdm2, int *odir)
if (rate / (bits_per_sample * 2 * 8) < APLL_I2S_MIN_RATE)
return ESP_FAIL;
/* For maximum flexibility, we need to target the APLL frequency, fout, to be in the middle of its range,
or its geometric mean. Thus start with fout = sqrt(APLL_I2S_MIN_RATE * APLL_I2S_MIN_RATE).
In order to produce our target rate, we figure the divisor needed to get close from the mean APLL frequency.
Starting with the equation relating fout, rate, and o_div:
rate = fout / ((o_div + 2) * 2)
We solve for o_div:
(o_div + 2) * 2 = fout / rate
o_div + 2 = fout / (2 * rate)
o_div = fout / (2 * rate) - 2
and can now calculate it directly. After rounding o_div to the nearest integer, we plug it back into the
formula and solve for sdm, which is really just a fixed-point number with 6 bits of integer part and 16
bits of fraction. It only needs to be split into sdm0, sdm1, and sdm2 when we load it into the hardware
registers.
First, recalculate the actual fout using the integer version of o_div:
fout = rate * ((o_div + 2) * 2)
then use this value to calculate sdm by solving the following for sdm:
fout = xtal_freq * (4 + sdm / 65536)
4 + sdm / 65536 = fout / xtal_freq
sdm / 65536 = fout / xtal_freq - 4
sdm = 65536 * (fout / xtal_freq - 4)
sdm, rounded and converted to an integer, can now be broken into sub-registers:
sdm2 = sdm >> 16
sdm1 = (sdm >> 8) & 0x000000ff
sdm0 = sdm & 0x000000ff
/* not sure why a factor of 4 is needed in two places below; the docs imply it should be 2 */
float o_div_f = (float) APLL_GEO_MEAN_FREQ / (float)(4 * rate) - 2.0;
*odir = (int)floorf(o_div_f + 0.5f);
float fout = (float)(rate * (*odir + 2) * 4);
float f_xtal = (float)rtc_clk_xtal_freq_get() * 1000000.0f;
int sdm = (int)floorf(65536.0f * (fout / f_xtal - 4.0f) + 0.5f);
*sdm2 = sdm >> 16;
*sdm1 = (sdm >> 8) & 0x000000ff;
*sdm0 = sdm & 0x000000ff;
return ESP_OK;
FWIW, a fair few of them already are documented in the TRM; at least the I2C one is. We're going to look into the others as well, and check if we need to put them in the TRM or the ECO document.There are many HW bugs in ESP32 peripherals that should be mentioned in the "ECO and Workarounds for Bugs in ESP32" document.
In that case there should be another document describing all known HW bugs like it is common among other manufacturers.FWIW, a fair few of them already are documented in the TRM; at least the I2C one is. We're going to look into the others as well, and check if we need to put them in the TRM or the ECO document.
Not sure if having another document helps here, but we're always open to suggestions. Do you have an example of what you would expect a document like that to look at?In that case there should be another document describing all known HW bugs like it is common among other manufacturers.
Sent PM.Not sure if having another document helps here, but we're always open to suggestions. Do you have an example of what you would expect a document like that to look at?
Please put a hard-to-miss note in the API/Programming guides wherever there is known H/W bug.Not sure if having another document helps here, but we're always open to suggestions.
bump SPI flash commands
- SPI flash options in SPI registers are not documented (e. g. SPI_FLASH_READ, SPI_FLASH_WREN in SPI_CMD_REG register)
