About the CAN controller.
Re: About the CAN controller.
Postby Sprite » Wed Mar 22, 2017 4:02 am
Rudi: That would be the choice of the author of that driver. If he wants, he can file a pull request in the esp-idf github and we'll check the code quality and such and if that's OK, we will integrate it into esp-idf. If he prefers to have the driver as a separate component, that is fine too.
Postby rudi ;-) » Wed Mar 22, 2017 8:08 am
I know the theoretical throughput ;)
At 1MBit you should be able to push out a little less than 8000 frames per second.
Did you really see 20 - 50 ms between frames, or are these µs?
Still a lot, considering a fast frame is only a bit more than 100µs...
Cheers
Hans
sry for confusion,
here in a test, that i can see the messages on receiver side with printf,
i have a delay in code between next send, sure you can have lees value of delay in the "house-can-bus or openCAN end firmware :P :
void task_CAN_TX(void* pvParameters) {
	CAN_frame_t __TX_frame;
	uint32_t counter = 0;
		__TX_frame.MsgID = 0x264;
		__TX_frame.DLC   =  8;
		__TX_frame.data.u8[0] = 'E';
		__TX_frame.data.u8[1] = 'S';
		__TX_frame.data.u8[2] = 'P';
		__TX_frame.data.u8[3] = '-';
		__TX_frame.data.u8[4] = 'C';
		__TX_frame.data.u8[5] = 'A';
		__TX_frame.data.u8[6] = 'N';
		__TX_frame.data.u8[7] = counter;
while(1) {
		CAN_write_frame(&__TX_frame);
		vTaskDelay( 50 / portTICK_PERIOD_MS);  // to see ( printf on receiver side ) what happend..
		counter++;
		if (counter >= 256) counter = 0;
Postby rudi ;-) » Wed Mar 22, 2017 8:36 am
no problem with the author jeroen, he did pleased me too comments and make it ready for the structure of ESP-IDF as driver so that we can add according to guidelines. with little changes and menuconfig gaves the CAN Driver at last the finnish and is now ready,
as Driver in ESP-IDF or/and third party and a example code is ready too.
i do next time create a repo for this, upload it for people how wants use it yet with menuconfig,
i do then make a PR to the author repo as "third party", then the author can make a PR to ESP-IDF repo or "third party"
why this a little confuse is, the author willl have no access to a computer for the next weeks....nothing creepy
and i can not add Contributor License Agreement things in order of espressif.. cause have not the legal capacity to create contracts in Espressifs name.
so the author then can confirm later itself Contributor License Agreement if he makes the PR.
DL88AI88
Postby DL88AI88 » Wed Mar 22, 2017 12:32 pm
Hi there,
I tried to compile the previously named CAN example
I get an error like this:
/ESP32-CAN/main///main.c:102:1: fatal error: opening dependency file //main.d: Permission denied
Is there further configuration of the source file needed?
Best regards
DL88AI88
Postby rudi ;-) » Wed Mar 22, 2017 1:41 pm
hi
if you work in a VM which os you use as host and which os you use as gast?
if you in a OS, in which os you work?
rudi
$ make -j5 all
Building partitions from /c/idf/2114/components/partition_table/partitions_singleapp.csv...
CC bt.o
CC esp_ota_ops.o
CC src/bootloader_random.o
CC libcoap/src/address.o
AR libbt.a
CC src/flash_encrypt.o
CC libcoap/src/async.o
CXX cxx_guards.o
AR libapp_update.a
CC src/esp_image_format.o
CC rtc_module.o
CC src/flash_partitions.o
CC libcoap/src/block.o
CC src/secure_boot_signatures.o
CC i2c.o
CC libcoap/src/coap_time.o
CC src/secure_boot.o
CC src/efuse.o
CC libcoap/src/debug.o
CC src/bootloader_flash.o
CC sdmmc_host.o
AR libbootloader_support.a
CC libcoap/src/encode.o
AR libcxx.a
CC timer.o
CC int_wdt.o
CC libcoap/src/hashkey.o
CC libcoap/src/mem.o
CC brownout.o
CC emac_main.o
CC sdmmc_transaction.o
CC system_api.o
CC libcoap/src/net.o
CC rmt.o
CC hw_random.o
CC emac_dev.o
CC cpu_freq.o
AR libethernet.a
CC pcnt.o
CC libcoap/src/option.o
CC event_loop.o
CC core_dump.o
CC libcoap/src/pdu.o
CC src/efuse.o
CC gpio.o
CC library/xmltok_impl.o
CC intr_alloc.o
CC libcoap/src/resource.o
CC library/xmlrole.o
CC ledc.o
CC ipc.o
CC libcoap/src/str.o
CC library/xmlparse.o
CC log.o
CC freertos_hooks.o
CC libcoap/src/subscribe.o
CC periph_ctrl.o
CC heap_alloc_caps.o
AR liblog.a
CC libcoap/src/uri.o
CC i2s.o
CC deep_sleep.o
CC port/coap_io_socket.o
CC uart.o
CC phy_init.o
CC library/xmltok.o
CC spi_flash_rom_patch.o
CC crosscore_int.o
AR libcoap.a
AR libspi_flash.a
CC sigmadelta.o
CC cpu_util.o
CC spi_master.o
CC gdbstub.o
CC micro-ecc/uECC.o
CC lib_printf.o
CC cpu_start.o
CC src/option/unicode.o
AR libdriver.a
CC library/xmltok_ns.o
AR libmicro-ecc.a
CC src/option/syscall.o
CC task_wdt.o
CC port/chardata.o
CC xtensa_overlay_os_hook.o
CC flash_qio_mode.o
CC src/diskio.o
CC event_default_handlers.o
CC FreeRTOS-openocd.o
CC port/expat_element.o
CC bootloader_start.o
CC src/vfs_fat.o
CC timers.o
CC port/minicheck.o
CC panic.o
CC tasks.o
AR libmain.a
CC src/vfs_fat_sdmmc.o
AR libexpat.a
CC hwcrypto/aes.o
CC hwcrypto/sha.o
CC src//jsmn.o
CC src/ff.o
LD bootloader.elf
CC event_groups.o
AR libjsmn.a
AR libesp32.a
CC heap_regions.o
CC log.o
AR libfatfs.a
CC library/cJSON.o
AR liblog.a
CC port.o
esptool.py v2.0-beta2
CC xtensa_init.o
CC mdns.o
CC port/cJSON_Utils.o
CC list.o
CC apps/dhcpserver.o
CC croutine.o
AR libjson.a
CC queue.o
CC micro-ecc/uECC.o
CC library/havege.o
CC xtensa_intr.o
CC heap_regions_debug.o
AR libmicro-ecc.a
AR libmdns.a
CC library/ssl_cookie.o
CC core/tcp_out.o
CC ringbuf.o
CC locks.o
CC syscall_table.o
CC core/udp.o
AS portasm.o
CC library/md5.o
AS xtensa_vectors.o
CC syscalls.o
CC core/def.o
CC library/nghttp2_map.o
CC library/certs.o
CC reent_init.o
AS xtensa_context.o
CC core/timers.o
CC time.o
CC library/ssl_ciphersuites.o
CC library/nghttp2_submit.o
AS xtensa_intr_asm.o
AR libfreertos.a
CC library/camellia.o
AR libnewlib.a
CC core/stats.o
CXX src/nvs_api.o
CC core/netif.o
CC library/x509_crl.o
CC library/nghttp2_queue.o
CC library/ssl_stack.o
CC core/pbuf.o
CC library/nghttp2_pq.o
CC library/threading.o
CC library/aesni.o
CC library/nghttp2_hd_huffman_data.o
CC library/ssl_lib.o
CC library/bignum.o
CC core/tcp_in.o
CC library/nghttp2_outbound_item.o
CC library/ssl_x509.o
CC library/arc4.o
CC library/nghttp2_frame.o
CC core/raw.o
CC library/ssl_pkey.o
CC library/cipher_wrap.o
CC core/ip.o
CC library/ssl_methods.o
CC library/nghttp2_helper.o
CXX src/nvs_storage.o
CC library/aes.o
CC core/dns.o
CC library/ssl_cert.o
CC library/nghttp2_npn.o
CC library/xtea.o
CC platform/ssl_port.o
CC library/nghttp2_option.o
CC core/tcp.o
CC library/base64.o
CC platform/ssl_pm.o
CC library/nghttp2_buf.o
CC core/sys.o
CC library/sha512.o
CC library/pkcs11.o
CC library/nghttp2_priority_spec.o
CC core/memp.o
AR libopenssl.a
CC library/asn1write.o
CC library/nghttp2_hd.o
CXX src/nvs_pagemanager.o
CC sdmmc_cmd.o
CC core/init.o
CC library/oid.o
AR libsdmmc.a
CC core/inet_chksum.o
CC library/ecjpake.o
CC library/nghttp2_stream.o
CC core/mem.o
CC library/ssl_tls.o
CXX src/nvs_item_hash_list.o
CC library/nghttp2_session.o
CC api/lwip_debug.o
CC api/sockets.o
CXX src/nvs_page.o
CC flash_ops.o
CC library/debug.o
CC library/net.o
CC library/ecdh.o
CC api/api_msg.o
CXX src/nvs_types.o
CC library/nghttp2_callbacks.o
CC cache_utils.o
CC library/x509_crt.o
CC library/nghttp2_rcbuf.o
CC api/err.o
CC library/nghttp2_hd_huffman.o
AR libnvs_flash.a
CC api/netbuf.o
CC library/ssl_srv.o
CC partition.o
CC tcpip_adapter_lwip.o
CC library/nghttp2_mem.o
CC api/tcpip.o
CC library/nghttp2_version.o
CC flash_mmap.o
CC api/netifapi.o
AR libtcpip_adapter.a
CC library/ecdsa.o
CC library/nghttp2_http.o
CC api/api_lib.o
AR libspi_flash.a
CC library/md2.o
CC port/http_parser.o
CC ulp.o
CC vfs.o
CC library/x509_create.o
CC api/netdb.o
CC vfs_uart.o
AR libulp.a
CC library/memory_buffer_alloc.o
AR libvfs.a
CC api/pppapi.o
CC library/gcm.o
CC apps/sntp/sntp.o
AR libnghttp.a
CC trax.o
CC library/version.o
CC src/crypto/ms_funcs.o
CC eri.o
CC apps/ping/esp_ping.o
CC library/pem.o
AR libxtensa-debug-module.a
CC apps/ping/ping.o
CC src/crypto/crypto_internal-cipher.o
CC library/padlock.o
CC core/ipv4/icmp.o
CC library/asn1parse.o
CC src/crypto/crypto_internal-modexp.o
CC core/ipv4/autoip.o
CC library/timing.o
CC src/crypto/bignum.o
CC core/ipv4/ip4.o
CC library/ssl_cli.o
CC library/pkwrite.o
CC core/ipv4/igmp.o
CC src/crypto/sha1-pbkdf2.o
CC core/ipv4/ip4_addr.o
CC library/ssl_cache.o
CC src/crypto/aes-cbc.o
CC core/ipv4/dhcp.o
CC library/sha256.o
CC src/crypto/md5.o
CC library/md_wrap.o
CC core/ipv4/ip_frag.o
CC src/crypto/rc4.o
CC core/ipv6/icmp6.o
CC library/entropy.o
CC src/crypto/sha256.o
CC core/ipv6/ethip6.o
CC core/ipv6/mld6.o
CC library/md.o
CC src/crypto/dh_groups.o
CC core/ipv6/nd6.o
CC core/ipv6/ip6.o
CC library/rsa.o
CC src/crypto/md4-internal.o
CC core/ipv6/ip6_addr.o
CC src/crypto/sha1-internal.o
CC library/ripemd160.o
CC core/ipv6/inet6.o
CC core/ipv6/dhcp6.o
CC core/ipv6/ip6_frag.o
CC src/crypto/aes-wrap.o
CC netif/ethernetif.o
CC library/version_features.o
CC src/crypto/crypto_internal.o
CC netif/lowpan6.o
CC netif/ethernet.o
CC library/cipher.o
CC netif/etharp.o
CC src/crypto/dh_group5.o
CC netif/slipif.o
CC port/freertos/sys_arch.o
CC src/crypto/des-internal.o
CC library/entropy_poll.o
CC port/netif/ethernetif.o
CC src/crypto/crypto_internal-rsa.o
CC port/netif/wlanif.o
CC library/dhm.o
CC src/crypto/aes-unwrap.o
AR liblwip.a
CC library/error.o
CC src/crypto/aes-internal-dec.o
CC src/crypto/sha1.o
CC src/crypto/aes-internal.o
CC library/ssl_ticket.o
CC library/x509.o
CC src/crypto/md5-internal.o
CC src/crypto/sha256-internal.o
CC library/blowfish.o
CC library/ecp.o
CC src/crypto/aes-internal-enc.o
CC library/md4.o
CC port/os_xtensa.o
CC library/x509_csr.o
CC library/pkparse.o
AR libwpa_supplicant.a
CC library/pkcs5.o
CC library/ccm.o
CC library/pkcs12.o
CC library/pk_wrap.o
CC library/ecp_curves.o
CC library/x509write_crt.o
CC library/ctr_drbg.o
CC library/platform.o
CC library/pk.o
CC library/x509write_csr.o
CC library/des.o
CC library/hmac_drbg.o
CC library/sha1.o
CC port/esp_sha512.o
CC port/esp_hardware.o
CC port/esp_bignum.o
CC port/esp_sha256.o
CC port/net.o
CC port/esp_sha1.o
CC port/mbedtls_debug.o
AR libmbedtls.a
CC //main.o
CC drv/CAN/CAN.o
CC drv/CAN/cfg/CAN_config.o
AR libmain.a
LD CAN_demo.elf
To flash all build output, run 'make flash' or:
python /c/idf/2114/components/esptool_py/esptool/esptool.py --chip esp32 --port com21 --baud 921600 --before default_reset --after hard_reset write_flash -u --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 /home/sysop/testcan/build/bootloader/bootloader.bin 0x10000 /home/sysop/testcan/build/CAN_demo.bin 0x8000 /home/sysop/testcan/build/partitions_singleapp.bin
DL88AI88
Postby DL88AI88 » Wed Mar 22, 2017 10:54 pm
No vm.
Just Ubuntu Linux 16.10.
All other examples are being built without issues.
best regards
DL88AI88
DL88AI88
Postby DL88AI88 » Thu Mar 23, 2017 10:54 am
OK, I solved it like this:
in component.mk I changed
COMPONENT_ADD_INCLUDEDIRS := / drv/CAN/include
COMPONENT_SRCDIRS := / drv/CAN drv/CAN/cfg
to
COMPONENT_ADD_INCLUDEDIRS := . drv/CAN/include
COMPONENT_SRCDIRS := . drv/CAN drv/CAN/cfg
Now it compiles.
best regards
DL88AI88
Postby rudi ;-) » Sat Mar 25, 2017 4:55 pm
@jeroen
CAN Driver as component and menuconfig now online on my git
Pullrequest to the author is done
extended frames in work
Hans Dorn
Postby Hans Dorn » Sat Mar 25, 2017 5:33 pm
Nice.
Dont't forget about those pesky RTR frames :P
Cheers
Postby rudi ;-) » Sat Mar 25, 2017 6:07 pm
Nice.
:D
german
http://translate.google.com
english
Users browsing this forum: Baidu [Spider], ChatGPT-User and 1 guest
