list(APPEND cxx_compile_options "-std=gnu++11" "-fno-rtti")
set (CMAKE_CXX_STANDARD 17)
set (CMAKE_CXX_STANDARD_REQUIRED 17)
set (CMAKE_CXX_EXTENSIONS OFF)
Linking CXX executable test.elf
esp-idf/esp32/libesp32.a(crosscore_int.c.obj):(.iram1.literal+0xc): undefined reference to `_frxt_setup_switch'
esp-idf/esp32/libesp32.a(crosscore_int.c.obj): In function `esp_crosscore_isr':
~/esp/esp-idf/components/esp32/crosscore_int.c:67: undefined reference to `_frxt_setup_switch'
esp-idf/esp32/libesp32.a(dport_access.c.obj):(.literal.dport_access_init_core+0x14): undefined reference to `xt_ints_off'
esp-idf/esp32/libesp32.a(dport_access.c.obj):(.literal.dport_access_init_core+0x1c): undefined reference to `xt_ints_on'
esp-idf/esp32/libesp32.a(dport_access.c.obj): In function `dport_access_init_core':
~/esp/esp-idf/components/esp32/dport_access.c:169: undefined reference to `xt_ints_off'
~/esp/esp-idf/components/esp32/dport_access.c:171: undefined reference to `xt_ints_on'
esp-idf/esp32/libesp32.a(esp_timer.c.obj): In function `timer_alarm_handler':
~/esp/esp-idf/components/esp32/esp_timer.c:318: undefined reference to `_frxt_setup_switch'
esp-idf/esp32/libesp32.a(int_wdt.c.obj): In function `esp_int_wdt_cpu_init':
~/esp/esp-idf/components/esp32/int_wdt.c:96: undefined reference to `xt_ints_off'
~/esp/esp-idf/components/esp32/int_wdt.c:97: undefined reference to `xt_ints_on'
esp-idf/esp32/libesp32.a(intr_alloc.c.obj):(.iram1.literal+0x8): undefined reference to `xt_ints_on'
esp-idf/esp32/libesp32.a(intr_alloc.c.obj):(.iram1.literal+0x18): undefined reference to `xt_ints_off'
esp-idf/esp32/libesp32.a(intr_alloc.c.obj):(.literal.is_vect_desc_usable+0x10): undefined reference to `_xt_interrupt_table'
esp-idf/esp32/libesp32.a(intr_alloc.c.obj): In function `esp_intr_enable':
~/esp/esp-idf/components/esp32/intr_alloc.c:811: undefined reference to `xt_ints_on'
esp-idf/esp32/libesp32.a(intr_alloc.c.obj): In function `esp_intr_disable':
~/esp/esp-idf/components/esp32/intr_alloc.c:851: undefined reference to `xt_ints_off'
esp-idf/esp32/libesp32.a(intr_alloc.c.obj): In function `esp_intr_noniram_enable':
~/esp/esp-idf/components/esp32/intr_alloc.c:883: undefined reference to `xt_ints_on'
esp-idf/esp32/libesp32.a(intr_alloc.c.obj): In function `ets_isr_unmask':
~/esp/esp-idf/components/esp32/intr_alloc.c:899: undefined reference to `xt_ints_off'
esp-idf/esp32/libesp32.a(intr_alloc.c.obj): In function `esp_intr_alloc_intrstatus':
~/esp/esp-idf/components/esp32/intr_alloc.c:650: undefined reference to `xt_ints_on'
esp-idf/esp32/libesp32.a(system_api.c.obj): In function `esp_restart_noos':
~/esp/esp-idf/components/esp32/system_api.c:272: undefined reference to `xt_ints_off'
esp-idf/newlib/libnewlib.a(locks.c.obj): In function `lock_acquire_generic':
~/esp/esp-idf/components/newlib/locks.c:146: undefined reference to `_frxt_setup_switch'
esp-idf/newlib/libnewlib.a(locks.c.obj): In function `lock_release_generic':
~/esp/esp-idf/components/newlib/locks.c:194: undefined reference to `_frxt_setup_switch'
esp-idf/freertos/libfreertos.a(port.c.obj):(.literal.pxPortInitialiseStack+0x8): undefined reference to `_xt_user_exit'
esp-idf/freertos/libfreertos.a(port.c.obj):(.literal.xPortStartScheduler+0x0): undefined reference to `_xt_coproc_init'
esp-idf/freertos/libfreertos.a(port.c.obj):(.literal.xPortStartScheduler+0x4): undefined reference to `_frxt_tick_timer_init'
esp-idf/freertos/libfreertos.a(port.c.obj):(.literal.xPortStartScheduler+0x8): undefined reference to `_frxt_dispatch'
esp-idf/freertos/libfreertos.a(port.c.obj):(.literal.vPortReleaseTaskMPUSettings+0x0): undefined reference to `_xt_coproc_release'
esp-idf/freertos/libfreertos.a(port.c.obj): In function `xPortStartScheduler':
~/esp/esp-idf/components/freertos/port.c:264: undefined reference to `_xt_coproc_init'
~/esp/esp-idf/components/freertos/port.c:268: undefined reference to `_frxt_tick_timer_init'
~/esp/esp-idf/components/freertos/port.c:276: undefined reference to `_frxt_dispatch'
esp-idf/freertos/libfreertos.a(port.c.obj): In function `vPortReleaseTaskMPUSettings':
~/esp/esp-idf/components/freertos/port.c:325: undefined reference to `_xt_coproc_release'
esp-idf/freertos/libfreertos.a(xtensa_intr.c.obj):(.literal.xt_set_interrupt_handler+0x4): undefined reference to `_xt_interrupt_table'
esp-idf/esp32/libesp32.a(cache_err_int.c.obj): In function `esp_cache_err_int_init':
~/esp/esp-idf/components/esp32/cache_err_int.c:37: undefined reference to `xt_ints_off'
~/esp/esp-idf/components/esp32/cache_err_int.c:63: undefined reference to `xt_ints_on'
collect2: error: ld returned 1 exit status
CMakeFiles/test.elf.dir/build.make:129: recipe for target 'test.elf' failed
make[3]: *** [test.elf] Error 1
CMakeFiles/Makefile2:105: recipe for target 'CMakeFiles/test.elf.dir/all' failed
make[2]: *** [CMakeFiles/test.elf.dir/all] Error 2
CMakeFiles/Makefile2:875: recipe for target 'esp-idf/CMakeFiles/flash.dir/rule' failed
make[1]: *** [esp-idf/CMakeFiles/flash.dir/rule] Error 2
Makefile:372: recipe for target 'flash' failed
make rebuild_cache
make
/usr/local/bin/cmake -E cmake_link_script CMakeFiles/test.elf.dir/link.txt --verbose=1
~/esp/crosstool-NG/builds/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++ \
-mlongcalls -nostdlib CMakeFiles/test.elf.dir/main.cpp.obj \
-o test.elf \
dev/libdev.a \
utils/libutils.a \
hash/libhash.a \
fs/libfs.a \
-Wl,--gc-sections -Wl,--start-group esp-idf/soc/libsoc.a esp-idf/log/liblog.a \
esp-idf/heap/libheap.a esp-idf/xtensa-debug-module/libxtensa-debug-module.a \
esp-idf/app_trace/libapp_trace.a esp-idf/freertos/libfreertos.a \
esp-idf/vfs/libvfs.a esp-idf/newlib/libnewlib.a esp-idf/esp_ringbuf/libesp_ringbuf.a \
esp-idf/driver/libdriver.a esp-idf/esp_event/libesp_event.a esp-idf/ethernet/libethernet.a \
esp-idf/lwip/liblwip.a esp-idf/tcpip_adapter/libtcpip_adapter.a esp-idf/mbedtls/libmbedtls.a \
esp-idf/micro-ecc/libmicro-ecc.a esp-idf/bootloader_support/libbootloader_support.a \
esp-idf/spi_flash/libspi_flash.a esp-idf/app_update/libapp_update.a \
esp-idf/nvs_flash/libnvs_flash.a esp-idf/pthread/libpthread.a \
esp-idf/smartconfig_ack/libsmartconfig_ack.a esp-idf/wpa_supplicant/libwpa_supplicant.a \
esp-idf/esp32/libesp32.a esp-idf/cxx/libcxx.a -lgcov esp-idf/mbedtls/mbedtls/library/libmbedtls.a \
esp-idf/mbedtls/mbedtls/library/libmbedx509.a esp-idf/mbedtls/mbedtls/library/libmbedcrypto.a \
esp-idf/soc/libsoc.a esp-idf/log/liblog.a esp-idf/heap/libheap.a \
esp-idf/freertos/libfreertos.a -Wl,--undefined=uxTopUsedPriority esp-idf/newlib/libnewlib.a \
-L ~/esp/esp-idf/components/newlib/lib -lc-psram-workaround -lm-psram-workaround esp-idf/esp32/libesp32.a \
-L ~/esp/esp-idf/components/esp32/lib -lcoexist -lcore -lespnow -lmesh -lnet80211 \
-lphy -lpp -lrtc -lsmartconfig -lwpa2 -lwpa -lwps -L ~/code/test_sw/build_esp32/esp-idf/esp32 \
-T esp32_out.ld -T ~/code/test_sw/build_esp32/esp-idf/esp32/esp32.common.ld \
-L ~/esp/esp-idf/components/esp32/ld -T esp32.rom.ld -T esp32.peripherals.ld \
-T esp32.rom.libgcc.ld ~/esp/esp-idf/components/esp32/libhal.a -lgcc -u call_user_start_cpu0 \
-u ld_include_panic_highint_hdl esp-idf/cxx/libcxx.a -lstdc++ -u __cxa_guard_dummy -u esp_app_desc
xtensa-esp32-elf-nm esp-idf/freertos/libfreertos.a | grep _frxt_setup_switch
U _frxt_setup_switch
FreeRTOS-openocd.c.obj
croutine.c.obj
event_groups.c.obj
list.c.obj
port.c.obj
queue.c.obj
tasks.c.obj
timers.c.obj
xtensa_init.c.obj
xtensa_intr.c.obj
xtensa_overlay_os_hook.c.obj
croutine.c.obj
event_groups.c.obj
list.c.obj
port.c.obj
portasm.S.obj
queue.c.obj
tasks.c.obj
timers.c.obj
xtensa_context.S.obj
xtensa_init.c.obj
xtensa_intr.c.obj
xtensa_intr_asm.S.obj
xtensa_vector_defaults.S.obj
xtensa_vectors.S.obj
project (test C CXX ASM)
That's correct. Do you think a subproject would be more appropriate here?be cause all the IDF components are not actual cmake projects but they are just targets under the umbrella of the top-level project ...... or something like that? Hmm...
Users browsing this forum: Bing [Bot], RathiSonika and 2 guests
