[Video]: Bluetooth BLE and C++ classes
kalimanmer
Re: [Video]: Bluetooth BLE and C++ classes
Neil, this issue is fixed, I used your post https://github.com/espressif/esp-idf/issues/857
BLE Sample Scan not working
my esp32 is not scanning and fnction sample scan is also not rnning
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4560
ho 0 tail 12 room 4
load:0x40078000,len:0
load:0x40078000,len:13184
entry 0x40078d38
I (224) cpu_start: Pro cpu up.
I (224) cpu_start: Single core mode
I (224) heap_init: Initializing. RAM available for dynamic allocation:
I (228) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (234) heap_init: At 3FFC59D8 len 0001A628 (105 KiB): DRAM
I (240) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (246) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (253) heap_init: At 4008CFDC len 00013024 (76 KiB): IRAM
I (259) cpu_start: Pro cpu start user code
I (53) cpu_start: Starting scheduler on PRO CPU.
I (64) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (274) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
There is not much logs, could you change log level to debug or verbose?
Also one thing i can see now that is interesting:
With bluetooth working free DRAM should be less, about 84kB or less.
I (234) heap_init: At 3FFC59D8 len 0001A628 (105 KiB): DRAM-
misiek1994
Hello everybody,
Could anybody tell me if this project is still alive? I see last post from 2018 and the video is from 2017. Is there any newer version updated to ESP-IDF changes or any new object-oriented alternative to this API?
Regards
misiek
Regards
misiek
Users browsing this forum: Baidu [Spider], Bing [Bot], DuckDuckGo [Bot], Google [Bot], PerplexityBot, YisouSpider and 2 guests
