Uart Rx/tx
realfspin
Re: Uart Rx/tx
Postby realfspin » Fri May 31, 2024 7:44 pm
Thank you tremendously, I've finally gotten some time to sit down and try this and it seems your advice has helped me gain some progress.
So, with this code below, I am able to connect both my rx and tx lines together and then connect them into an active connection from jtag2updi and snoop it's updi commands being sent while it programs an attiny. This is a step up from only being able to connect the rx line without causing (what I assume was) line contention.
I am also able to send messages on my tx line and immediately read them back on my rx line, so I feel like everything should be working...
Alas, even when I send the same commands as jtag2updi I'm apparently still not getting any response from my attiny, and of course it's hard to tell whether the problem lay in the uart setup or some detail of the updi protocol.
  // UART configuration
  uart_config_t uart_config = {
  .baud_rate = UPDI_BAUD,
  .parity = UART_PARITY_EVEN,
  .stop_bits = UART_STOP_BITS_2,
  .flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
  .rx_flow_ctrl_thresh = 0,
  .source_clk = UART_SCLK_APB,
  // Configure UART parameters
  uart_param_config(UPDI_UART_NUM, &uart_config);
  // Set UART pins
  uart_set_pin(UPDI_UART_NUM, UPDI_RX_PIN, UPDI_TX_PIN, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
  // Install UART driver
  uart_driver_install(UPDI_UART_NUM, 1024 * 2, 0, 0, NULL, 0);
  // Set UART read timeout
  uart_set_rx_timeout(UPDI_UART_NUM, 50);
  const gpio_config_t pin_cfg {
    .pin_bit_mask = (1ul << GPIO_NUM_8) | (1ul << GPIO_NUM_2),
    .mode = GPIO_MODE_INPUT_OUTPUT_OD, // Input and Output w/ open-drain!
    .pull_up_en = GPIO_PULLUP_ENABLE, // Open-drain requires a pull-up.
    .pull_down_en = GPIO_PULLDOWN_DISABLE,
    .intr_type = GPIO_INTR_DISABLE
  gpio_config(&pin_cfg);
  esp_rom_gpio_connect_out_signal(UPDI_TX_PIN, UART_PERIPH_SIGNAL(UPDI_UART_NUM, SOC_UART_TX_PIN_IDX), false, false);
  esp_rom_gpio_connect_in_signal(UPDI_RX_PIN, UART_PERIPH_SIGNAL(UPDI_UART_NUM, SOC_UART_RX_PIN_IDX), false);
I'm assuming that at this point there's probably not much more you can do to help me, and we are probably going outside the scope of this thread. But if you do happen to have any more insight it would be greatly appreciated.
I have another thread here discussing tx/rx on the same line, although what we're doing here is effectively good enough if I can just connect two lines together.
https://esp32.com/posting.php?mode=reply&f=13&t=40073
MicroController
Re: Uart Rx/tx
Postby MicroController » Sat Jun 01, 2024 7:41 am
(How) do you send a BREAK to reset/synchronize?
RandomInternetGuy
Re: Uart Rx/tx
Postby RandomInternetGuy » Sun Jun 09, 2024 11:31 am
This question doesn't seem to be related to the seven year old thread you resurrected.
Your question seems to be "how do I send a break", which isn't really appropriate in the hardware group at all, but it's documented in ESP-IDF.
uart_write_bytes_with_break() is covered in many places, but notably https://docs.espressif.com/projects/esp ... /uart.html
When it's time to receive one, you'll get a UART_BREAK event, as described at https://docs.espressif.com/projects/esp ... /uart.html
If a follow-up is necessary, I'd suggest doing so in a new thread, after searching existing threads, and including a short, self-contained, stand-alone ESP-IDF program where you can demonstrate a use of uart_write_bytes_with_break() not sending a break. I suspect it won't be necessary, but ESP-IDF hasn't always been bug-free in this area as BREAKs are pretty uncommonly used these days.
In fact, they'd be completly unusable in the context this was originally asked because you need one sender and one receiver and that needs to be negotiated externally to the communication itself.
MicroController
Re: Uart Rx/tx
Postby MicroController » Sun Jun 09, 2024 3:22 pm
Your question seems to be "how do I send a break"...
Well, no. My question is if and how @realfspin does send a BREAK as required by the UPDI protocol he's struggling to get running ;)
realfspin
Re: Uart Rx/tx
Postby realfspin » Tue Jun 11, 2024 10:22 am
Just to be clear, the original advice about open drain helped me significantly which was indeed related to the thread.
But yes, discussing the updi break is probably outside the scope of this thread. Although, I wonder if maybe RandomInternetGuy fell prey to the pagination and opened this 7 year old thread only to see your post (first of page 2) asking how to send a break to reset synchronize :lol:
Anyway, when I snoop on jtag2updi and I use the hardware uart listener I do actually receive something like 0x00 0x00 0x55 ... where the first two bytes appear to be a double break as per updi spec, and then followed by a 55 and a updi command which matches the source code of jtag2updi.
All of this said, I have made significant progress and acquired a cheap digital scope to look at my signal and I think I've been able to pinpoint several more problems, one was in my break length, and the other seems to be in my ability to bitbang a square signal.
I am still having issues but I feel that my issues probably belong in a new thread at this point. I will continue the discussion here:
https://esp32.com/viewtopic.php?f=13&t=40073
MicroController
Re: Uart Rx/tx
Postby MicroController » Tue Jun 11, 2024 10:27 am
Definitely :) The board software takes no prisoners :D
realfspin
Re: Uart Rx/tx
Postby realfspin » Thu Jun 13, 2024 6:15 am
So, after further investigation, I believe the issue is still line contention even with the code given before.
I believe this is back on track with the thread purpose, a combined rx/tx line that alternates between rx and tx.
Is there anything we are missing with the uart initialization or control?
MicroController
Re: Uart Rx/tx
Postby MicroController » Thu Jun 13, 2024 9:47 am
Another idea: The internal pull-up of the ESP (~50k) may be a bit weak. You can try adding an external pull up resistor, 5-10k maybe, to try and improve the signal quality.
realfspin
Re: Uart Rx/tx
Postby realfspin » Fri Jun 14, 2024 2:19 am
well I've given up and fallen back on bitbanging, seems that using a bit timing of 200us has worked, maybe other timings work too.
I think the problem is the tx line was holing the line HIGH so the attiny couldn't respond and pull the line low.
I'm sure it's possible with the hardware uart but from what I can see I have it working and I would rather not waste more time.
Thanks guys
Users browsing this forum: ChatGPT-User, Qwantbot and 4 guests
