Low Rate WIFI Protocol LR
Postby rudi ;-) » Wed Jan 18, 2017 8:08 pm
 uint32_t low_rate_enable:1;           /**< bit: 0 flag to identify if low rate is enabled or not */
 #define WIFI_PROTOCOL_11B         1
#define WIFI_PROTOCOL_11G         2
#define WIFI_PROTOCOL_11N         4
#define WIFI_PROTOCOL_LR           8
hi guys,
get we low rate for long range ?
some results from 1/4 Mbps testings?
Re: Low Rate WIFI Protocol LR
Postby rudi ;-) » Thu Jan 19, 2017 9:39 am
hi
.. this Wifi Protocol LR was just mentioned here?
ESP_igrr
Postby ESP_igrr » Thu Jan 19, 2017 11:57 am
@Rudi: my long range test didn't go well because of a mechanical problem on the test vehicle (motor support plate fell apart). Will try again when I figure out how to 3d print a new one...
Postby rudi ;-) » Thu Jan 19, 2017 5:21 pm
@ivan txs, - (would help you on 3d print, but have not started this theme - but next time i do this too )
btw: txs for fixing some issues on git
peter_
Postby peter_ » Fri Feb 17, 2017 8:52 pm
are there any news about this topic? This mode sounds very interesting for me because I don't need a really high datarate but a high range.
Is it compatible with normal routers? (I don't think so.)
Regards
Peter
Postby rudi ;-) » Tue Mar 21, 2017 6:50 pm
nice 3D Work
https://twitter.com/i_grr/status/822698239946354691
any news from this Low Rate?
Hans Dorn
Postby Hans Dorn » Tue Mar 21, 2017 8:34 pm
Your car broke down while checking the range?
Sounds good enough to me :P
Cheers
P.S J/K
Postby rudi ;-) » Wed Mar 29, 2017 9:54 am
we know,
Low Range is here in the master since JAN
and to set things are here:
  * @brief     Set protocol type of specified interface
  *            The default protocol is (WIFI_PROTOCOL_11B|WIFI_PROTOCOL_11G|WIFI_PROTOCOL_11N)
  * @attention Currently we only support 802.11b or 802.11bg or 802.11bgn mode
  * @param     ifx  interfaces
  * @param     protocol_bitmap  WiFi protocol bitmap
  * @return
  *    - ESP_OK: succeed
  *    - ESP_ERR_WIFI_NOT_INIT: WiFi is not initialized by eps_wifi_init
  *    - ESP_ERR_WIFI_IF: invalid interface
  *    - others: refer to error codes in esp_err.h
esp_err_t esp_wifi_set_protocol(wifi_interface_t ifx, uint8_t protocol_bitmap);
and we must simple set to WIFI_PROTOCOL_LR ?
is it now supported in the actually ESP-IDF ?
i am little confuse now :mrgreen:
code snippet for setup to set LR available?
ESP_igrr
Postby ESP_igrr » Wed Mar 29, 2017 10:27 am
Well this is basically one function call... so not sure what kind of snippet you need, but here's a piece of one of my applications:
void init_wifi(wifi_mode_t mode)
    const uint8_t protocol = WIFI_PROTOCOL_LR;
    tcpip_adapter_init();
    ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
    ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
    ESP_ERROR_CHECK( esp_wifi_set_mode(mode) );
    wifi_event_group = xEventGroupCreate();
    if (mode == WIFI_MODE_STA) {
        ESP_ERROR_CHECK( esp_wifi_set_protocol(WIFI_IF_STA, protocol) );
        wifi_config_t config = {
            .sta = {
                .ssid = ap_name,
                .password = pass,
                .bssid_set = false
        ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_STA, &config) );
        ESP_ERROR_CHECK( esp_wifi_connect() );
        xEventGroupWaitBits(wifi_event_group, CONNECTED_BIT,
                            false, true, portMAX_DELAY);
        ESP_LOGI(TAG, "Connected to AP");
        ESP_ERROR_CHECK( esp_wifi_set_protocol(WIFI_IF_AP, protocol) );
            .ap = {
                .ssid = ap_name,
                .password = pass,
                .ssid_len = 0,
                .authmode = WIFI_AUTH_WPA_WPA2_PSK,
                .ssid_hidden = false,
                .max_connection = 3,
                .beacon_interval = 100,
        ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_AP, &config) );
Some variables are defined outside of the snippet, but hopefully you can figure it out.
Postby rudi ;-) » Wed Mar 29, 2017 10:45 am
            .sta = {
                .ssid = ap_name,
                .password = pass,
                .bssid_set = false
            .ap = {
                .ssid = ap_name,
                .password = pass,
                .ssid_len = 0,
sometime things so hard -
sometime things so easy
this snippet line declare all and do the job
thank you ivan! my tomatoes are away ;-)
will try ( weekend outside ) .. and let you know
Users browsing this forum: Bytespider, ChatGPT-User, meta-externalagent and 3 guests
