Proper way to disable AP
Posted: Sun Apr 07, 2019 9:17 am
This thread on github indicates that i should be able to disable the AP by simply changing the mode to WIFI_MODE_STA
https://github.com/espressif/esp-idf/issues/2433
Only when i try doing that i get the error below, and my board reboots.
In fact, doing any of these things seems to give me the error and reboot my board:
What might i be doing wrong?
WiFi.mode(WIFI_MODE_STA);Code: Select all
WiFi.enableAP(false);
WiFi.softAPdisconnect();
WiFi.softAPdisconnect(false);What might i be doing wrong?
Guru Meditation Error: Core 0 panic'ed (Interrupt wdt timeout on CPU0)
Core 0 register dump:
PC : 0x4008ff67 PS : 0x00060a34 A0 : 0x80091101 A1 : 0x3ffb5520
A2 : 0x3ffbdd14 A3 : 0x0000cdcd A4 : 0xb33fffff A5 : 0x00000001
A6 : 0x00060823 A7 : 0x0000abab A8 : 0x0000cdcd A9 : 0x3ffb5660
A10 : 0x3ffc5548 A11 : 0x00060623 A12 : 0x00060620 A13 : 0x3ffb5708
A14 : 0x00000009 A15 : 0x3ffc86a4 SAR : 0x0000001e EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Backtrace: 0x4008ff67:0x3ffb5520 0x400910fe:0x3ffb5550 0x4008f4ef:0x3ffb5570 0x400864cf:0x3ffb55b0 0x400865a9:0x3ffb55e0 0x400e2197:0x3ffb5600 0x40118a81:0x3ffb5630 0x4012e64d:0x3ffb5660 0x4012e7be:0x3ffb5680 0x40118b90:0x3ffb56a0 0x40118f83:0x3ffb56d0 0x40088768:0x3ffb56f0 0x4008e875:0x3ffb5730
Core 1 register dump:
PC : 0x40091958 PS : 0x00060434 A0 : 0x80090ada A1 : 0x3ffbe6e0
A2 : 0x3ffb595c A3 : 0x3ffb8074 A4 : 0x00000001 A5 : 0x00000001
A6 : 0x00060423 A7 : 0x00000000 A8 : 0x3ffb8074 A9 : 0x3ffb8074
A10 : 0x00000018 A11 : 0x00000018 A12 : 0x00000001 A13 : 0x00000001
A14 : 0x00060421 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000005
Backtrace: 0x40091958:0x3ffbe6e0 0x40090ad7:0x3ffbe700 0x4008f58f:0x3ffbe720 0x40083d95:0x3ffbe760 0x40119081:0x3ffbe780 0x4010d088:0x3ffbe7a0 0x400d81e1:0x3ffbe7d0 0x400d3739:0x3ffbe8d0 0x40080f8e:0x3ffbe8f0 0x40081255:0x3ffbe910 0x40081761:0x3ffbe930 0x4000bfed:0x00000000
