Low speed on Wifi and character loss
M3te0ra2
Postby M3te0ra2 » Wed Apr 10, 2019 9:46 am
I'm using TCP sockets over WiFi to connect one ESP32 with a Python client on my computer. I'm also using a BLE server at the same time and UART to communicate with my main board. I want to download files received on UART to my computer. The thing is, I'm having a quite low speed (between 200 and 300 kbps). What's more, if I activate the BLE, I receive corrupted files because some characters are lost during transmission between my main board and the ESP, on one packet out of 5 roughly.
My question is, is it normal that the Wifi is so slow? I'm having quite bad speed with http_server example but the iperf example gives me correct results. I'm using ESP-IDF v3.1.3. And why am I losing data on the UART only when I activate the BLE?
Socket code on ESP32:
Code: Untitled.c Select all
int write_wifi(const char* response, int len) {
if(len > BUF_SIZE) {
ESP_LOGE(SOCK_TAG, "Too long response");
return 1;
strncpy(write_buffer, response, len);
write_len = len;
xTaskNotifyGive(tcpTaskHandle);
return 0;
static void tcp_server_task(void *pvParameters) {
char rx_buffer[128];
char addr_str[128];
int addr_family;
int ip_protocol;
while(1) {
#ifdef CONFIG_EXAMPLE_IPV4
struct sockaddr_in destAddr;
destAddr.sin_addr.s_addr = htonl(INADDR_ANY);
destAddr.sin_family = AF_INET;
destAddr.sin_port = htons(PORT);
addr_family = AF_INET;
ip_protocol = IPPROTO_IP;
inet_ntoa_r(destAddr.sin_addr, addr_str, sizeof(addr_str) - 1);
#else // IPV6
struct sockaddr_in6 destAddr;
bzero(&destAddr.sin6_addr.un, sizeof(destAddr.sin6_addr.un));
destAddr.sin6_family = AF_INET6;
destAddr.sin6_port = htons(PORT);
addr_family = AF_INET6;
ip_protocol = IPPROTO_IPV6;
inet6_ntoa_r(destAddr.sin6_addr, addr_str, sizeof(addr_str) - 1);
#endif
int listen_sock = socket(addr_family, SOCK_STREAM, ip_protocol);
ESP_LOGI(SOCK_TAG, "Socket created");
int on = 1;
int err = setsockopt(listen_sock, SOL_SOCKET, SO_REUSEADDR, (char*)&on, sizeof(on));
err = bind(listen_sock, (struct sockaddr *)&destAddr, sizeof(destAddr));
ESP_LOGI(SOCK_TAG, "Socket binded");
err = listen(listen_sock, 1);
ESP_LOGI(SOCK_TAG, "Socket listening");
while (1) {
struct sockaddr_in6 sourceAddr; // Large enough for both IPv4 or IPv6
uint addrLen = sizeof(sourceAddr);
int sock = accept(listen_sock, (struct sockaddr *)&sourceAddr, &addrLen);
if (sock < 0) {
ESP_LOGE(SOCK_TAG, "Unable to accept connection: errno %d", errno);
ESP_LOGI(SOCK_TAG, "Socket accepted");
uart_write_bytes(UART_NUM_1, "@wifi_connected\n", 16);
while (1) {
int len = recv(sock, rx_buffer, sizeof(rx_buffer) - 1, 0);
// Test the request
// Get the sender's ip address as string
if (sourceAddr.sin6_family == PF_INET) {
inet_ntoa_r(((struct sockaddr_in *)&sourceAddr)->sin_addr.s_addr, addr_str, sizeof(addr_str) - 1);
} else if (sourceAddr.sin6_family == PF_INET6) {
inet6_ntoa_r(sourceAddr.sin6_addr, addr_str, sizeof(addr_str) - 1);
rx_buffer[len] = 0; // Null-terminate whatever we received and treat like a string
ESP_LOGI(SOCK_TAG, "Received %d bytes from %s on socket", len, addr_str);
wifi_response = 1;
uart_write_bytes(UART_NUM_1, rx_buffer, len);
ulTaskNotifyTake(pdTRUE, portMAX_DELAY); // Will be woken up when write_wifi() is called
send(sock, write_buffer, write_len, 0);
close(sock);
uart_write_bytes(UART_NUM_1, "@wifi_disconnected\n", 19);
vTaskDelete(NULL);
UART code on ESP32:
Code: uart.c Select all
int current_len;
int uartstate;
char read_data[BUF_SIZE];
static void read_UART()
uartstate = UART_WAITING;
// Read data from the UART
int len = uart_read_bytes(UART_NUM_1, read_data + current_len, BUF_SIZE-1-current_len, 20 / portTICK_RATE_MS);
current_len += len;
read_data[current_len] = '\0';
if(len > 0) {
ESP_LOGI(TAG, "Received %d bytes on UART. current_len = %d", len, current_len);
//If '\n' is detected
if (strchr((char*)read_data, '\n') || current_len == BUF_SIZE-1) {
if (read_data[0] == '@') {
uartstate = COMMAND_RECEIVED;
// Process command
ESP_LOGD(TAG, "Command received");
} else if(wifi_response) { // wifi_response is set to 1 when we get a request from Wifi, so that the answer can be sent to Wifi
write_wifi((char*)read_data, current_len);
wifi_response = 0;
//the message is for the BLE
uartstate = WRITE_CHARACTERISTIC;
// write to BLE
current_len = 0;
sdkconfig:
# Wi-Fi
CONFIG_SW_COEXIST_ENABLE=y
CONFIG_SW_COEXIST_PREFERENCE_WIFI=
CONFIG_SW_COEXIST_PREFERENCE_BT=
CONFIG_SW_COEXIST_PREFERENCE_BALANCE=y
CONFIG_SW_COEXIST_PREFERENCE_VALUE=2
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=16
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=64
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER=
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=1
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM=64
CONFIG_ESP32_WIFI_CSI_ENABLED=
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=32
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=32
CONFIG_ESP32_WIFI_NVS_ENABLED=y
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0=y
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_1=
CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN=752
# Bluetooth
CONFIG_BT_ENABLED=y
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_0=y
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_1=
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE=0
CONFIG_BTDM_CONTROLLER_HCI_MODE_VHCI=y
CONFIG_BTDM_CONTROLLER_HCI_MODE_UART_H4=
# MODEM SLEEP Options
CONFIG_BTDM_CONTROLLER_MODEM_SLEEP=y
CONFIG_BTDM_MODEM_SLEEP_MODE_ORIG=y
CONFIG_BTDM_MODEM_SLEEP_MODE_EVED=
CONFIG_BTDM_LPCLK_SEL_MAIN_XTAL=y
CONFIG_BLUEDROID_ENABLED=y
CONFIG_BLUEDROID_PINNED_TO_CORE_0=y
CONFIG_BLUEDROID_PINNED_TO_CORE_1=
CONFIG_BLUEDROID_PINNED_TO_CORE=0
CONFIG_BTC_TASK_STACK_SIZE=3072
CONFIG_BLUEDROID_MEM_DEBUG=
CONFIG_CLASSIC_BT_ENABLED=y
CONFIG_A2DP_ENABLE=y
CONFIG_A2DP_SINK_TASK_STACK_SIZE=2048
CONFIG_A2DP_SOURCE_TASK_STACK_SIZE=2048
CONFIG_BT_SPP_ENABLED=
CONFIG_HFP_ENABLE=
CONFIG_GATTS_ENABLE=y
CONFIG_GATTC_ENABLE=y
CONFIG_GATTC_CACHE_NVS_FLASH=
CONFIG_BLE_SMP_ENABLE=y
CONFIG_BT_STACK_NO_LOG=
Thanks in advance
M3te0ra2
Re: Low speed on Wifi and character loss
Postby M3te0ra2 » Thu Apr 11, 2019 1:48 pm
No one?
littlesky
Postby littlesky » Fri Apr 19, 2019 7:54 am
Is the sdkconfig the same as the iperf example? Did you enable WiFi and BT software coexist?
Users browsing this forum: Baidu [Spider], Bing [Bot] and 1 guest
