I am able to drive a TFT display using SPI with 4 wires which are CS, CLK, MOSI, D/C. But recently, I am working on driving another TFT display using SPI with only CS, CLK, MOSI (without D/C pin). The trick is that I need to add once more bit in front of the 8 bits data/command I want to send. And that bit indicates whether the following 8 bits is command or not. Is it possible for esp32 to send 9 bit signal a time. What is the best way to implement it? Is there any limitation to that (i.e. cannot use dma)?
Please comment, thank you.
Thanks,
Jones
About Driving TFT with 3-wire SPI (no D/C pin, 9 bit data)
Re: About Driving TFT with 3-wire SPI (no D/C pin, 9 bit data)
It's no different from other ways to control a SPI device, but you have to keep in mind that you need to pack the 9 bits of the data into the 8 bits you feed into the SPI peripheral. So for instance, a 3x9-bit transaction would have this data: dc 7 6 5 4 3 2 1 | 0 dc 7 6 5 4 3 2 | 1 0 dc 7 6 5 4 3 | 2 1 x x x x (Note that I'm not sure about the word or bit ordering, but you get the idea I hope.)
Hi ngjones,
have you found a good way to perform this succesfully?
I am running into the same issue while trying to control an OLED display with 3-wire SPI.
Thanks a lot in advance,
- MZ
- MZ
Just in case someone else comes here:
I tried to follow @ESP_Sprite's suggestion and it worked great. I was afraid I had to toggle CS line after every 9 bits, but it appears it's not required as long as I keep CS low all the time.
Thank you @ESP_Sprite!
The way I've done it is by creating a buffer to write data into SPI. Using uint16_t is enough.
I append 9 bits on every write attempt and when my buffer length is over 8 bits, then I push those 8-bits into SPI.
I also had to add some dummy write of 0x00 at the end in case when I have less than 8 bits of data when everything is completed.
electronicsguy
- Contact:
@nochkin Could you share your code?Just in case someone else comes here:
There is an example I found which works with the Lilygo displays:
https://github.com/crosser/lvgl_esp_lcd
@electronicsguy
Sorry for delay man. I'm doing things differently now and could not find the code right away.
Anyway, I used ESP32-S3 connected using 3-wire SPI to SD2828 controller. I use LovyanGFX lib.
I have my own custom init code, but the config looks the following (adjust the references from SD2828 to whatever you need):
I _think_ this is the code I used to achieve that.
class LGFX_SSD2828_SPI : public lgfx::LGFX_Device
Panel_SSD2828 _panel_instance;
lgfx::Bus_SPI _bus_instance;
public:
LGFX_SSD2828_SPI(void)
auto cfg = _bus_instance.config();
cfg.freq_write = 10 * 1000000;
cfg.pin_dc = -1; // not needed
cfg.pin_miso = -1; // not needed
cfg.pin_mosi = MY_SSD2828_SDI;
cfg.pin_sclk = MY_SSD2828_SCLK;
cfg.spi_3wire = true;
cfg.spi_host = SPI3_HOST;
_bus_instance.config(cfg);
_panel_instance.setBus(&_bus_instance);
auto cfg = _panel_instance.config();
cfg.pin_cs = MY_SSD2828_CS;
cfg.pin_rst = MY_SSD2828_RST;
cfg.pin_busy = -1;
cfg.panel_width = 1;
cfg.panel_height = 1;
cfg.offset_x = 0;
cfg.offset_y = 0;
cfg.offset_rotation = 0;
cfg.dummy_read_pixel = 8;
cfg.dummy_read_bits = 1;
cfg.readable = false;
cfg.invert = false;
cfg.rgb_order = false;
cfg.dlen_16bit = false;
cfg.bus_shared = false;
_panel_instance.config(cfg);
setPanel(&_panel_instance);
Users browsing this forum: Amazon [Bot], ChatGPT-User, PetalBot and 2 guests
