Use I2S in I2S_MODE_DAC_BUILT_IN Mode
Posted: Fri Jan 20, 2017 2:21 pm
by BuddyCasino
I found the sample code in i2s.h, and noticed that we can use the built-in DAC to render I2S audio.
However I can't seem to get it working.
This is my init function:
static void init_i2s_dac()
    i2s_config_t i2s_config = {
        .mode = I2S_MODE_MASTER | I2S_MODE_TX | I2S_MODE_DAC_BUILT_IN,          // Only TX
        .sample_rate = 44100,
        .bits_per_sample = 8,                                                   // Only 8-bit DAC support
        .channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,                           // 2-channels
        .communication_format = I2S_COMM_FORMAT_I2S_MSB,
        .dma_buf_count = 14,                                                    // number of buffers, 128 max.
        .dma_buf_len = 32*2,                                                    // size of each buffer
        .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1                                // Interrupt level 1
    i2s_pin_config_t pin_config = {
        .bck_io_num = 26,
        .ws_io_num = 25,
        .data_out_num = 22,
        .data_in_num = I2S_PIN_NO_CHANGE                                          // Not used
    i2s_driver_install(I2S_NUM, &i2s_config, 0, NULL);
    i2s_set_pin(I2S_NUM, &pin_config);
My normal I2S pipeline works fine, but when I use the DAC, I get DMA and buffer underruns.
I feed it samples like this:
static int convert_sample(short s) {
    // convert 16bit to 8bit and duplicate mono sample to both channels
    char eightBit = s >> 8;
    short samp = eightBit;
    samp = (samp) & 0xff;
    samp = (samp << 8) | samp;
    return samp;
Any idea whats wrong?
Re: Use I2S in I2S_MODE_DAC_BUILT_IN Mode
Posted: Wed Jan 25, 2017 4:05 am
by telanoc
Doesn't this do the same thing?
    return s & 0xff00 | s >> 8;
Posted: Wed Jan 25, 2017 8:49 pm
by telanoc
Hmm... I think I should have typed
return (unsigned short) s & 0xff00 | (unsigned short) s >> 8;
:oops:
Posted: Fri Jan 27, 2017 9:19 am
by BuddyCasino
Probably, yes. I'm not very experienced with C though, so the commonly known bit-twiddling idioms don't come easy to me, yet. This method should return a short btw (2 x 8 Bit), my mistake. Not that this fixes anything.
Posted: Sun Jan 29, 2017 3:48 am
by Sprite
Fyi, it seems the I2S driver has a bug in DAC mode: the sample rate it sets is actually 8 times the sample rate you tell it to use. I have a bug fix in the internal merge queue, it will probably be merged after the holidays.
Posted: Sun Jan 29, 2017 5:15 am
by WiFive
Interesting is that because all the bits are latched into the DAC register on one clock edge?
Posted: Sun Jan 29, 2017 7:20 am
by Sprite
I think the DAC mode is one of the odd ones that uses BCLK as the latch clock. All other parallel modes seem to use WS for that. Not entirely sure; I can't really ask the hw people at this moment.
Posted: Mon Jan 30, 2017 9:56 am
by BuddyCasino
Thanks for the feedback! Bit of a relief to finally know the cause.
