SPI does not send address in master mode
Posted: Thu Apr 18, 2019 2:41 pm
I am struggling with SPI in master mode.
I want to send address plus buffer with help of function spi_device_queue_trans but SPI does not send address and send only data.
SPI device is configured like this:
SPI function to send data is as follow:
With this configuration SPI sends only data buffer and not address.
Target is to send address plus data.
Do you have any idea what could be wrong in my code, please?
Thank you
spi_device_interface_config_t sx1276_config = {
.clock_speed_hz = (SPI_SX1276_BUS_CLOCK_MHZ), //Clock out at 10 MHz.
.mode=0, //SPI mode 0 (CPOL=0, CPHA=0)
.spics_io_num = PIN_NUM_SX1276_CS, //CS pin
.queue_size = 1, //Transaction queue size.
.address_bits = 8,
.cs_ena_pretrans = 1, //one clock delay prior CS line is active
.cs_ena_posttrans= 1, //one clock delay after CS line is released
//Initialise the SPI bus for both devices
spi_error_ret=spi_bus_initialize(HSPI_HOST, &spi_bus_config, NO_SPI_DMA_CHANNEL);
ESP_ERROR_CHECK(spi_error_ret); //SPI bus error handling
//Attach to SPI bus
spi_error_ret = spi_bus_add_device(HSPI_HOST, &sx1276_config, &spi_sx1276_handle);
ESP_ERROR_CHECK(spi_error_ret); //SPI bus error handlingCode: Select all
static void spi1_Send_Data_To_SX1276_Device(spi_device_handle_t spi_sx1276_handle, uint8_t addr, uint8_t *buffer, uint16_t size)
static spi_transaction_t spi_transaction;
memset(&spi_transaction, 0, sizeof(spi_transaction_t));
[Codebox=c file=Untitled.c][Codebox=c file=Untitled.c][/Codebox][/Codebox]
spi_transaction.flags = SPI_DEVICE_HALFDUPLEX; //SPI_TRANS_USE_TXDATA,
spi_transaction.addr = (uint8_t) addr;
spi_transaction.length = 8 + (size * 8); // data length is in bits
spi_transaction.tx_buffer = buffer;
spi_transaction.rx_buffer = NULL;
spi_error_ret = spi_device_queue_trans(spi_sx1276_handle, &spi_transaction, SPI_SX1276_TICKS_TIMEOUT_MS); //queue data to send
}Target is to send address plus data.
Thank you
