Can't send data with a UDP socket as a broadcast
Posted: Thu Apr 25, 2019 2:51 pm
by dimfred
I have posted the question on stackoverflow. Hope that maybe someone here can help.
https://stackoverflow.com/questions/558 ... e-on-esp32
Main thing is I know in my example, that my server works. When I send data over the terminal as a broadcast the server receives. My socket also works, because on sendto it returns the correct number of bytes. I have no idea what the problem is. Is there anything in the config I have to enable to allow a broadcast leave the esp32???
Open for any suggestion
Greets Dimfred
Re: Can't send data with a UDP socket as a broadcast
Posted: Fri Apr 26, 2019 2:23 am
by Alvin
Hi, Dimfred
Thanks for sharing the issue, and also saw you seemed to know how this issue happened on the website of https://stackoverflow.com/questions/558 ... e-on-esp32. Thanks.
Alvin
Posted: Fri Apr 26, 2019 3:18 pm
by dimfred
Hello Alvin,
thank you for your response.
Now I have another question, since I still have problems of acquiring the antenna for wifi, while the a2dp sink is active. Could you maybe explain some steps on how I could achieve my a2dp sink + sending wifi? I am currently sending ~2 packages/min, but have ~3000/min coming from the a2dp. So not the best rate :D
I thought of looking for a a2dp sink task semaphore, but I couldn't find any. Would be great if you could help.
Greetings Dimfred
Posted: Sun Apr 28, 2019 1:46 am
by Sprite
Suggest you open a different topic for that, as it has nothing to do with UDP broadcasts.
