SPI pull down CS
Ian777
SPI pull down CS
Postby Ian777 » Fri Apr 26, 2019 2:58 pm
Hey everyone,
I've got my SPI init code defined as the following:
#define GPIO_MOSI 21
#define GPIO_MISO 14
#define GPIO_SCLK 12
#define GPIO_CS 22
    ESP_LOGI(TAG1,"Started master SPI");
    esp_err_t ret;
    spi_device_handle_t handle;
    //Configuration for the SPI bus
    spi_bus_config_t buscfg={
        .mosi_io_num=GPIO_MOSI,
        .miso_io_num=GPIO_MISO,
        .sclk_io_num=GPIO_SCLK,
        .quadwp_io_num=-1,
        .quadhd_io_num=-1
    spi_device_interface_config_t devcfg={
        .command_bits=0,
        .address_bits=0,
        .dummy_bits=0,
        .clock_speed_hz=5000000,
        .duty_cycle_pos=128,        //50% duty cycle
        .mode=0,
        .spics_io_num=GPIO_CS,
        .cs_ena_posttrans=3,        //Keep the CS low 3 cycles after transaction, to stop slave from missing the last bit when CS has less propagation delay than CLK
        .queue_size=3
Is there anyway to set the CS pin mode as a pull down as I have an external pullup resistor on the line?
Thanks in advance for any help!
Ritesh
Contact:
Re: SPI pull down CS
Postby Ritesh » Sun Apr 28, 2019 9:49 am
Hey everyone,
#define GPIO_CS 22
    esp_err_t ret;
        .quadwp_io_num=-1,
        .quadhd_io_num=-1
        .command_bits=0,
        .address_bits=0,
        .dummy_bits=0,
        .mode=0,
        .queue_size=3
I think there is no any way to make it pull down as you have already connected pull up resistor. But still try with making gpio configuration as pull down but I am sure it won't work as you required.
Still, Can you please question into hardware section then might be you will get proper solution for same.
Regards,
Ritesh Prajapati
Ian777
Postby Ian777 » Mon Apr 29, 2019 10:14 am
Hey everyone,
#define GPIO_CS 22
    esp_err_t ret;
        .quadwp_io_num=-1,
        .quadhd_io_num=-1
        .command_bits=0,
        .address_bits=0,
        .dummy_bits=0,
        .mode=0,
        .queue_size=3
Thank you Ritesh, I've cross-posted his to the hardware section. I appreciate the help.
Postby Sprite » Tue Apr 30, 2019 1:48 am
I've moved this to the hardware topic and closed the other topics. Please do not cross-post; it risks information being scattered around the forums.
Users browsing this forum: Bing [Bot], PetalBot and 1 guest
