Sinus Signal Generator from 18Hz to 250kHz
HelWeb
Postby HelWeb » Sun Apr 28, 2019 10:10 pm
From this excellent work as base
https://github.com/krzychb/dac-cosine
I build a signal generator to produce sinus signals from 18Hz to 250kHz.
From 50Hz to 100kHz the difference to the wished frequency is about 1%
And it works without CPU after initialisation.
Code: Untitled.c Select all
// Function generator Sin
// (C) Helmut Weber
// Provided as is as example
// Free for everyone
// 50 Hz - 200000Hz: frequency error ~ 1%
// from 17 Hz - 250000 possible
// based on:
// https://github.com/krzychb/dac-cosine
// clk_8m_div and frequency_step are computed to give the best result for the wished frequency
/* DAC Cosine Generator Example
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "soc/rtc_io_reg.h"
#include "soc/rtc_cntl_reg.h"
#include "soc/sens_reg.h"
#include "soc/rtc.h"
#include "driver/dac.h"
/* Declare global sine waveform parameters
* so they may be then accessed and changed from debugger
* over an JTAG interface
// Esp32 @ 240 MHz:
// f=125.6*step/(div+1) [div=0..7] [calc: (div+1)]
// step0:
// 0=15.61Hz 1=--
// step 1:
// 0 = 125.6 Hz 1 = 62.50 Hz 2 = 41.67Hz 3=31.35Hz 4=25.00Hz 5=20.92Hz 6=17.86Hz 7=15.63Hz
// step 2:125,6
// 0= 250.0 Hz 1=125Hz 2=83.68 Hz 3=62.5 Hz 4=50.1 Hz 5=41.74Hz 6=35.74 Hz 7=31.35Hz
// step 10
// 0 = 1.248 kHz 1 = 625.4 Hz 2 = 417.4 Hz (noisy) 3 = 31.33 Hz 4 = 250.6 5 = 208.3 Hz 6=178.9 7=156.3
// step 100:
// 0: 12.53 kHz 1 = 6.266 kHz 2=4.173kHz 3= 3.127 kHz 4=2.505 kHz 6=1.789 kHz 7=1.565KHz
// step 500:
// 0: 62.54 kHz (noisy) 1 = 31.33 kHz 2 = 20.86 kHz 5 = 10.5 kHz 6 =20.88 KhZ 7=
// step 1000:
// 0 = 125 kHz, 1 = 62.11 kHz, 5 = 20.73 kHz ==>>> 10 = 42.02 kHz 100
// step 2000
// 0: 249.4 kHz(unten verzerrt) 1 = 125.8 kHz (noisy) 5 = 41.5 kHz (noisy)
int clk_8m_div = 1; // RTC 8M clock divider (division is by clk_8m_div+1, i.e. 0 means 8MHz frequency)
int frequency_step = 7; // Frequency step for CW generator
int scale = 1; // 50% of the full scale // scale 0 == fill scale = bad signal (no longer a sine wave)
int offset; // leave it default / 0 = no any offset
int invert = 2; // invert MSB to get sine waveform // 3: invert 180°
* Enable cosine waveform generator on a DAC channel
void dac_cosine_enable(dac_channel_t channel)
// Enable tone generator common to both channels
SET_PERI_REG_MASK(SENS_SAR_DAC_CTRL1_REG, SENS_SW_TONE_EN);
switch(channel) {
case DAC_CHANNEL_1:
// Enable / connect tone tone generator on / to this channel
SET_PERI_REG_MASK(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_CW_EN1_M);
// Invert MSB, otherwise part of waveform will have inverted
SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_INV1, 2, SENS_DAC_INV1_S);
case DAC_CHANNEL_2:
SET_PERI_REG_MASK(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_CW_EN2_M);
SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_INV2, 2, SENS_DAC_INV2_S);
default :
printf("Channel %d\n", channel);
* Set frequency of internal CW generator common to both DAC channels
* clk_8m_div: 0b000 - 0b111
* frequency_step: range 0x0001 - 0xFFFF
void dac_frequency_set(int clk_8m_div, int frequency_step)
REG_SET_FIELD(RTC_CNTL_CLK_CONF_REG, RTC_CNTL_CK8M_DIV_SEL, clk_8m_div);
SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL1_REG, SENS_SW_FSTEP, frequency_step, SENS_SW_FSTEP_S);
* Scale output of a DAC channel using two bit pattern:
* - 00: no scale
* - 01: scale to 1/2
* - 10: scale to 1/4
* - 11: scale to 1/8
void dac_scale_set(dac_channel_t channel, int scale)
switch(channel) {
case DAC_CHANNEL_1:
SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_SCALE1, scale, SENS_DAC_SCALE1_S);
case DAC_CHANNEL_2:
SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_SCALE2, scale, SENS_DAC_SCALE2_S);
default :
* Offset output of a DAC channel
* Range 0x00 - 0xFF
void dac_offset_set(dac_channel_t channel, int offset)
switch(channel) {
case DAC_CHANNEL_1:
SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_DC1, offset, SENS_DAC_DC1_S);
case DAC_CHANNEL_2:
SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_DC2, offset, SENS_DAC_DC2_S);
default :
* Invert output pattern of a DAC channel
* - 00: does not invert any bits,
* - 01: inverts all bits,
* - 10: inverts MSB,
* - 11: inverts all bits except for MSB
void dac_invert_set(dac_channel_t channel, int invert)
switch(channel) {
case DAC_CHANNEL_1:
SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_INV1, invert, SENS_DAC_INV1_S);
case DAC_CHANNEL_2:
SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_INV2, invert, SENS_DAC_INV2_S);
default :
* Main task that let you test CW parameters in action
void dactask(void* arg)
double f, f_target, delta, delta_min=9999999.0;
int step_target=0, divi_target=0;
//From experiments: f=125.6*step/(div+1)
// this frequency is wanted:
f_target=127000.0; // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
// check all combinations of step iand divi to get the best guess:
for (int step=1;step<2000; step++) {
for (int divi=0; divi<8; divi++) {
f=125.6*(double)step/(double)(divi+1);
delta= abs((f_target-f));
if (delta < delta_min) {delta_min=delta; step_target=step; divi_target=divi; }
clk_8m_div=divi_target;
frequency_step=step_target;
printf("divi=%d step=%d\n",divi_target, step_target);
while(1){
// frequency setting is common to both channels
dac_frequency_set(clk_8m_div, frequency_step);
/* Tune parameters of channel 2 only
* to see and compare changes against channel 1
dac_scale_set(DAC_CHANNEL_2, scale);
dac_offset_set(DAC_CHANNEL_2, offset);
dac_invert_set(DAC_CHANNEL_2, invert);
float frequency = RTC_FAST_CLK_FREQ_APPROX / (1 + clk_8m_div) * (float) frequency_step / 65536;
printf("THEORIE: clk_8m_div: %d, frequency step: %d, frequency: %.0f Hz\n", clk_8m_div, frequency_step, frequency);
printf("PRACTICAL: frequency: %.0f Hz\n", 125.6*(float)frequency_step /(1 + (float)clk_8m_div) );
printf("DAC2 scale: %d, offset %d, invert: %d\n", scale, offset, invert);
vTaskDelay(2000/portTICK_PERIOD_MS);
* Generate a sine waveform on both DAC channels:
* DAC_CHANNEL_1 - GPIO25
* DAC_CHANNEL_2 - GPIO26
* Connect scope to both GPIO25 and GPIO26
* to observe the waveform changes
* in response to the parameter change
void app_main()
dac_cosine_enable(DAC_CHANNEL_1);
dac_cosine_enable(DAC_CHANNEL_2);
dac_output_enable(DAC_CHANNEL_1);
dac_output_enable(DAC_CHANNEL_2);
xTaskCreate(dactask, "dactask", 1024*3, NULL, 10, NULL);
Fast is not fast enough :D
TinkerBearNZ
Re: Sinus Signal Generator from 18Hz to 250kHz
Postby TinkerBearNZ » Thu Jul 04, 2019 6:08 am
I'm looking at the esp32 Technical Reference Manual, section 28.5.4, and it says:
A phase-shift of 0 / 90 / 180 / 270 degrees can be added by setting register SENS_SAR_DAC_INVn[1:0].
Do you think this is just a documentation error? My experimentation with the invert values has discovered useful output with values of 2 (what's used in the demo code) and 3 (inverted), but 0 and 1 generate... odd waveforms. They look like a sign error of some sort.
TinkerBearNZ
Postby TinkerBearNZ » Tue Jul 09, 2019 10:52 pm
Some interesting trade-offs using this as a waveform generator.
If you use an RTC clock divider of 1, you get lovely smooth waveforms, but you can only generate multiples of ~131.6Hz (at least on my board). Waveforms up to the 500kHz range look pretty decent.
If you use an RTC clock divider of 8, you can generate multiples of ~16.6Hz, but with 8x fewer samples, so you start seeing stepping at 100kHz.
I'm wondering if they had a use case for this, and what it was?
joydipdns
Postby joydipdns » Thu Jan 16, 2020 7:47 am
I am new to esp32 and am using Arduino IDE. Can anyone suggest how this code can be written in Arduino IDE?
heinzv
Postby heinzv » Wed Mar 04, 2020 5:59 pm
I'm using a very similar code already in Arduino Studio. It should more or less work 1:1. Main function code needs to go to setup().
I have another very important question to the experts here:
I need a sine wave which shall sweep from 400Hz to 10kHz with 1Hz steps. The cosine works almost nicely BUT I could not find a way to have smaller steps thant 15.61Hz. I have tried to use the prescaler and the frequency_step but I guess there is no smooth way to get a 1Hz stepping with the combinations right?
What a pitty that the prescaler does not support a linar way to divide it to a single Hz step-width.
Gerdchen03
Postby Gerdchen03 » Thu Apr 23, 2020 7:21 am
I tried this code using copy past, but complier complains. I had to add:
Now I can compile and upload code, but I didn't get any sin wave.
joydipdns
Postby joydipdns » Thu Apr 23, 2020 8:52 am
Code: Untitled.txt Select all
I tried this code and it worked in arduino IDE for ESP32. Note: I used it to generate 200kHz and had steps in the output wave. Do change as per your need.
// (C) Helmut Weber
// based on:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
// Esp32 @ 240 MHz:
// step0:
// 0=15.61Hz 1=--
// step 1:
// step 2:125,6
 // step 10
 // step 100:
// step 500:
// step 1000:
// step 2000
    switch(channel) {
        case DAC_CHANNEL_1:
        case DAC_CHANNEL_2:
        default :
 * - 00: no scale
    switch(channel) {
        case DAC_CHANNEL_1:
        case DAC_CHANNEL_2:
        default :
 * Range 0x00 - 0xFF
    switch(channel) {
        case DAC_CHANNEL_1:
        case DAC_CHANNEL_2:
        default :
    switch(channel) {
        case DAC_CHANNEL_1:
        case DAC_CHANNEL_2:
        default :
    f_target=200000.0;                             // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    while(1){
void setup()
void loop()
rin67630
Postby rin67630 » Tue Apr 28, 2020 9:53 pm
You want to get a blazing fast sinus & cosinus generation without a lot of code?
Try that:
int X=0;
int Y=1000;
y1 = y1 - x1 / 16;
x1 = x1 + y1 / 16;
Unbelievable, but it generates a very nice and blazing fast sinus and cosinus on x and y!
Enjoy!
Gerdchen03
Postby Gerdchen03 » Wed Apr 29, 2020 10:08 pm
Thanks joydipdns, it works!!
I have to generate a broken sound that is beeping. Is there any possibility to set the wave for 300ms and have a delay of 100ms?
MickPF
Postby MickPF » Thu Dec 23, 2021 3:25 pm
Although I have been programming with ESP-IDF as a hobby for years, I have not yet dealt with the ESP32 registers at all.
In the context of this code, I don't understand why it is not possible to set the amplitude by calling "dac_output_voltage".
I modified this code for my purposes, but I can't change the signal amplitude.
Can someone please give me an explanation?
Thanks in advance,
Michael
