ESP BLE Mesh v0.6 Released, SIG Certified
Danialgreen
Re: ESP BLE Mesh v0.6 Released, SIG Certified
Postby Danialgreen » Wed Aug 28, 2019 7:32 am
Hi Espressif,
For the ESP32 fast provisioner client and server example, I configured my own pair of opcodes for sending and receive customer messages through the vendor model. The fast server model is able to receive customer messages from the fast client(by unicast address). However when the fast server sends status msg back to the fast client model. the function:
node = bt_mesh_is_model_message_publish(model, ctx, buf, false);
return a Null value. I checked the code, I found in
bt_mesh_client_pick_node(sys_slist_t *list, u16_t tx_dst)
it try to find the corresponding node with the same unicast address in a list from the fast client model->user_data->internal_data . For my code, this list is empty. In order to find the node, should I call some function to assign node list to the (bt_mesh_internal_data_t *)cli->internal_data?
Thank you!
Wangcheng
Postby Wangcheng » Thu Aug 29, 2019 11:42 am
Hi Espressif,
Thank you!
Hi Danialgreen,
1. You should not call the initialization function of the vender model. esp_ble_mesh_client_model_init .
2. If you still can't solve your problem, you need to provide a log, we will continue to pay attention.
Danialgreen
Postby Danialgreen » Fri Sep 06, 2019 7:05 am
Hi Espressif,
Thank you!
Hi Danialgreen,
Hi Wangcheng,
The code below is the log for fast provisioner client: after the fast server receives the message of opcode 0xc802e5 from fast provisioner client, it sends status msg back to the fast client model.
I expect to receive “ESP_BLE_MESH_MODEL_OPERATION_EVT” instead of “ESP_BLE_MESH_CLIENT_MODEL_RECV_PUBLISH_MSG_EVT”
I (11163) FAST_PROV_CLIENT_DEMO: ESP_BLE_MESH_PROVISIONER_PROV_COMPLETE_EVT
I (11163) FAST_PROV_CLIENT_DEMO: Node index: 0x0, unicast address: 0x05, element                                                             num: 1, netkey index: 0x00
I (11173) FAST_PROV_CLIENT_DEMO: Node uuid:  dddd30aea40ea8320000000000000000
I (11183) FAST_PROV_CLIENT_DEMO: ESP_BLE_MESH_PROVISIONER_SET_NODE_NAME_COMP_EVT                                                            , err_code: 0
*******Test_received rssi: -44I (11663) FAST_PROV_CLIENT_DEMO: example_config_cl                                                            ient_callback, error_code = 0x00, event = 0x01, addr: 0x0005
I (11663) FAST_PROV_OP: min:       0x0006, max:        0x7fff
I (11673) FAST_PROV_OP: flags:     0x00,   iv_index:   0x00000000
I (11683) FAST_PROV_OP: net_idx:   0x0000, group_addr: 0xc000
I (11683) FAST_PROV_OP: action:    0x81
I (11693) FAST_PROV_OP: match_val: dd dd
I (11693) FAST_PROV_CLIENT_DEMO: ESP_BLE_MESH_MODEL_SEND_COMP_EVT, err_code 0
*******Test_received rssi: -51I (12183) FAST_PROV_CLIENT_DEMO: example_custom_mo                                                            del_callback: Fast Prov Client Model receives status, opcode 0xc102e5
I (12183) fast prov client receives_T_O: 7f 00 00 00 00 00 00 00 00
I (12193) fast prov info status: 7f 00 00 00 00 00 00 00 00
I (13153) FAST_PROV_CLIENT_DEMO: ESP_BLE_MESH_PROVISIONER_PROV_LINK_CLOSE_EVT, bearer PB-ADV reason 0x00
I (13153) FAST_PROV_CLIENT_DEMO: PB-ADV link close, reason 0x00
W (15713) BLE_MESH: No matching TX context for ack
W (16113) BLE_MESH: No matching TX context for ack
W (16313) BLE_MESH: No matching TX context for ack
I (72203) FAST_PROV_CLIENT_DEMO: ESP_BLE_MESH_MODEL_SEND_COMP_EVT, err_code 0
*******Test_received rssi: -50I (72243) FAST_PROV_CLIENT_DEMO: example_custom_model_callback: Fast Prov Client Model receives status, opcode 0xc702e5
I (72243) fast prov client receives_T_O: 06 00
I (72253) Node address_T_O: 06 00
**************Give somaphore for LED**************
I (72273) FAST_PROV_CLIENT_DEMO: ESP_BLE_MESH_MODEL_SEND_COMP_EVT, err_code 0
*******Test_received rssi: -51************5***
I (72523) FAST_PROV_CLIENT_DEMO: ESP_BLE_MESH_MODEL_CLIENT_RECV_PUBLISH_MSG_EVT, opcode 0xc902e5
I (75263) FAST_PROV_CLIENT_DEMO: ESP_BLE_MESH_MODEL_SEND_COMP_EVT, err_code 0
*******Test_received rssi: -46************5***
I (75403) FAST_PROV_CLIENT_DEMO: ESP_BLE_MESH_MODEL_CLIENT_RECV_PUBLISH_MSG_EVT, opcode 0xc902e5
This is the mesh_client_model_op_cb function where I found the problem:
static void btc_ble_mesh_client_model_op_cb(struct bt_mesh_model *model,
        struct bt_mesh_msg_ctx *ctx,
        struct net_buf_simple *buf)
       if (node == NULL) {
        msg.act = ESP_BLE_MESH_CLIENT_MODEL_RECV_PUBLISH_MSG_EVT;
        mesh_param.client_recv_publish_msg.opcode = mesh_opcode;
        mesh_param.client_recv_publish_msg.model = (esp_ble_mesh_model_t *)model;
        mesh_param.client_recv_publish_msg.ctx = (esp_ble_mesh_msg_ctx_t *)ctx;
        mesh_param.client_recv_publish_msg.length = buf->len;
        mesh_param.client_recv_publish_msg.msg = buf->data;
        msg.act = ESP_BLE_MESH_MODEL_OPERATION_EVT;
        mesh_param.model_operation.opcode = mesh_opcode;
        mesh_param.model_operation.model = (esp_ble_mesh_model_t *)model;
        mesh_param.model_operation.ctx = (esp_ble_mesh_msg_ctx_t *)ctx;
        mesh_param.model_operation.length = buf->len;
        mesh_param.model_operation.msg = buf->data;
it try to find the corresponding node with the same unicast address in a list from the fast client user_data. For my code, this list is empty which print a ("**********5***").
bt_mesh_client_node_t *bt_mesh_is_model_message_publish(struct bt_mesh_model *model,
        struct net_buf_simple *buf,
        bool need_pub)
cli = (bt_mesh_client_common_t *)model->user_data;
rsp = ctx->recv_op;
data = (bt_mesh_internal_data_t *)cli->internal_data;
if ((node = bt_mesh_client_pick_node(&data->queue, ctx->addr)) == NULL) {
        printf("**********5***");
        BT_DBG("Unexpected status message 0x%x", rsp);
        if (cli->publish_status && need_pub) {
            cli->publish_status(rsp, model, ctx, buf);
        return NULL;
I think I implement my opcode pair the same way as other opcodes in fast provisioner client and server example,
it will be great if you have some hints for this problem, thank you!
Danialgreen
Postby Danialgreen » Fri Sep 06, 2019 7:37 am
The other two questions I have for the fast provisioner client and server example is that I try to program the MESH to do the following things:
1: to let fast provisioner(primary provisioner) direct send message to the top provisioner.
2: to let node direct send messages to other nodes or the fast provisioner.
For the first question, should I implement a fast prov server model to the ble_mesh_fast_prov_client example and use the fast_prov_client model from the Primary Provisioner to send a message to the Top Provisioner?
Or I can just use the fast_prov_server model to send a status message to the fast_prov_client model?
For the second question, I notice that the node with role ROLE_NODE is not allowed to use the fast_prov_client model to send message. Is there a way for the node direct send message to the fast provisioner and other nodes?
Thank you!
Maurizio
Postby Maurizio » Thu May 21, 2020 6:48 pm
Hi Danialgreen,
Hi Wangcheng,
       if (node == NULL) {
        bool need_pub)
rsp = ctx->recv_op;
        return NULL;
Hi Danialgreen, I was wondering if you ever found the solution to: "No matching TX context for ack" issue?
Benbu2018
Postby Benbu2018 » Tue Sep 22, 2020 8:46 pm
Hi Espressif,
I want to check if there is a way to know which advertising channel was received from the receiving side of the mesh node by the following method:
Is there a way to know which channel is used during the scanning process?
Is there a way to get the channel information from the received adv packet?
I was able to control which channel to use from advertising node. However, I want to use the it’s default advertising scheme.
I checked the adv.c and mesh_bearer_adapt.c file and didn't see an option for this. Please let me know if there's a way to do it from receiving side.
Thank you!
Daniel
Users browsing this forum: Baidu [Spider], ESP_alisitsyn and 39 guests
