pyelftools failes to install
TheBrick
Postby TheBrick » Wed May 08, 2019 8:34 am
Hello all,
Yes its one of those horrible initial install problems inevitable when setting up a new dev env which every experienced used will be shaking their head at the posters stupidity.
I am installing esp idf as per the getting started guide on windows.
https://docs.espressif.com/projects/esp ... et-esp-idf
When running:
python2 -m pip install --user -r $IDF_PATH/requirements.txt
I ran into problems with the cryptography package. This seems to be a common problem so I ran
python2 -m pip uninstall -y setuptools
pacman -S mingw-w64-i686-python2-setuptools mingw-w64-i686-python2-cryptography
as per some forum posts on here. I have then run into problems with the last package in requirments.txt, pyelftools.
if I run
python2 -m pip install pyelftools
I get
Collecting pyelftools
  Using cached https://files.pythonhosted.org/packages/fa/9a/0674cb1725196568bdbca98304f2efb17368b57af1a4bb3fc772c026f474/pyelftools-0.25.tar.gz
      0 [main] python2 765 child_info_fork::abort: address space needed by 'array.dll' (0x1E0000) is already occupied
    ERROR: Error [Errno 11] Resource temporarily unavailable while executing command python setup.py egg_info
ERROR: Could not install packages due to an EnvironmentError: [Errno 11] Resource temporarily unavailable
Could someone please give me a push in the correct direction.
Many Thanks
Tommy
Roland
Re: pyelftools failes to install
Postby Roland » Thu May 09, 2019 8:15 am
Hello TheBrick!
Did you download the ZIPed MSYS environment from the following link?
https://docs.espressif.com/projects/esp ... hain-setup
If you do so then the cryptography package should have been already included (together with the python interpreter).
Why are you have to use python2? "python" should be also a Python 2 interpreter.
What is the output the following command?
which python2
TheBrick
Postby TheBrick » Sun May 12, 2019 4:40 pm
Hi Roland,
Apologies for the slow reply am travelling / working.
That is indeed where I downloaded the mys2 from.
It was the next step within, Get ESP-IDF it titled "Installing required python packages":
https://docs.espressif.com/projects/esp ... n-packages
That failed. Python2 and the dependencies where defiantly not already installed.
TheBrick
Postby TheBrick » Sun May 12, 2019 5:39 pm
Hi Roland
Apologies for slow reply I have been working and travelling.
I am on Python 2.7.15
I did install from that link but no python installed so I used PACMAN to install python 2.
The problem occurred after installing msys2 during the "installing required python packages" section
TheBrick
Postby TheBrick » Sun May 12, 2019 6:21 pm
Apologises I misread your request for command output.
$ which python2
/usr/bin/python2
Angus
Postby Angus » Mon May 13, 2019 3:50 am
Hi TheBrick,
You need to run MSYS2 via the "mingw32.exe" or "MINGW32 Shell" launcher link. This sets up some different paths so your "python" will be /mingw32/bin/python .
MSYS2 has multiple different kinds of binaries all bundled in it, and they're only partly cross-compatible, so it can get a bit confusing.
In ESP-IDF V4.0 we plan to switch to cmake build system as the default and the Windows experience for developers should get a bit more familiar.
TheBrick
Postby TheBrick » Tue May 14, 2019 3:43 am
Ah Ha!!
That will indeed make a big difference! Thanks you ESP_Angus. I shall endeavor to continue with setting up my build system later in the week as time allows.
Users browsing this forum: ChatGPT-User, PetalBot, Qwantbot and 5 guests
