open and Files information do not comply with Posix specifications
ESPfri2
Postby ESPfri2 » Wed May 08, 2019 1:59 pm
this is the rework of my previous post "Incorrect File object information after file creation on a SD card and on SPIFFS"
I extended the investigation and modified the test program that lead me to conclude that the implementation of the Arduino ESP32 file manipulation do not comply with Posix specifications. As I was not able to find any documentation related to File for Arduino ESP32, I am supposing that Posix could be a good model.
The fact that the SD and SPIFFS implementation are different in behaviors tend also to prove that the implementations are incorrect.
The suppression of the truncate function do not help to my humble opinion, that's also the reason why I went to do this investigation ==> how to empty a file.
I have started to look at the Arduino ESP32 code, but obviously, I am not knowledgeable enough to correct that.
You will find at the end of this thread the new test program as well as the results I got.
:?: Does somebody knows to who should I send this information to get it challenged ? :?:
Thanks for your reading.
==================== old post =========================================
Just after creating a File on a SD card, the values returned by size() and available() are incorrect to me, they should be zero.
After a first write everything is back to normal, as you can see in the output below.
Is it a potential bug in the ESP32 package ?
for information, the same code running on a ESP8266 return zero.
thanks for your help.
#include <Arduino.h>
#include <SPI.h>
#include <SD.h>
File MFile;
  Serial.begin(9600);
  delay(3000);
  while (!Serial) {}
  Serial.println("Initializing SD card");
  if (!SD.begin(5)) {
    Serial.println("... initialization failed");
    return;
  Serial.println("initialization done");
  SD.remove("/f3.txt");
  MFile = SD.open("/f3.txt", "w+");
  if (!MFile)
   return;
  Serial.println("Just after open");
  Serial.print("Size           : "); Serial.println(MFile.size());
  Serial.print("Position       : "); Serial.println(MFile.position());
  Serial.print("Available data : "); Serial.println(MFile.available());
  MFile.println("nothing");
  MFile.flush();
  Serial.println("After the first write");
Output :
  • Initializing SD card
    initialization done
    Just after open
    Position : 0
    Available data : -16843010
    Position : 9
    Available data : 0
ESPfri2
Re: Incorrect File object informations after file creation on a SD card and on SPIFFS
Postby ESPfri2 » Fri May 10, 2019 12:30 pm
I extended the previous program to also tests SPIFFS and various file modes,
the results are badly impressive ... :o :shock:
To me there are clearly bugs, for example on SPIFFS, opening a non existing file in read mode will return a File object, when it clearly should not !
If a specialist of this can help me it would be great.
#include <SPIFFS.h>
#include <SPI.h>
#include <FS.h>
#include <SD.h>
#include <errno.h>
enum fstype {IsSD, IsSPIFFS};
char *fsname[] = {"SD card", "SPIFFS"};
char *NoYes[] = {"no", "yes"};
char c15[] = "0123456789ABCDF";
char CFilename[] = "/Test.txt";
File CFile;
void CreateFile(int FS, char *Mode) {
  Serial.println(">>>>>>>>>>>>>>>>>>");
  Serial.print  ("File on : ");Serial.println(fsname[FS]);
  Serial.println("  >> creation");
  Serial.print  ("     Mode : "); Serial.println(Mode);
  Serial.print  ("     Was existing     : ");
  if (FS == IsSD) {
    Serial.println(NoYes[SD.exists(CFilename)]);
    if (SD.exists(CFilename)) SD.remove(CFilename);
    CFile = SD.open(CFilename, Mode);
    Serial.println(NoYes[SPIFFS.exists(CFilename)]);
    if (SPIFFS.exists(CFilename)) SPIFFS.remove(CFilename);
    CFile = SPIFFS.open(CFilename, Mode);
  Serial.print("     Had been created : ");
  if (FS == IsSD) {
  Serial.print("  << result is : ");
  if (!CFile) {
    if (!strcmp("r", Mode))
      Serial.println("OK (File == 0)");
    else
      Serial.println("NOK !!!!!");
    return;
    if (!strcmp("r", Mode)) {
      Serial.println("NOK !!!!! (File != 0)");
      return;
    } else
      Serial.println("OK");
    if (!CFile)
  Serial.println("  >> Just after open");
  Serial.print("     Size           : "); Serial.println(CFile.size(), HEX);
  Serial.print("     Position       : "); Serial.println(CFile.position(), HEX);
  Serial.print("     Available data : "); Serial.println(CFile.available(), HEX);
  if (CFile.size()==0 && CFile.position()==0 && CFile.available()==0)
  else
  CFile.write((const uint8_t*)c15, strlen(c15));
  CFile.flush();
  Serial.println("  >> After the first write");
  Serial.print("     Size           : "); Serial.println(CFile.size());
  Serial.print("     Position       : "); Serial.println(CFile.position());
  Serial.print("     Available data : "); Serial.println(CFile.available());
  if (CFile.size()==strlen(c15) && CFile.position()==strlen(c15) && CFile.available()==0)
  else
  CFile.close();
  Serial.begin(9600);
  while (!Serial) {}
  Serial.println("Initializing ...");
  delay(3000);
  Serial.println("Initializing SPIFF");
  if(!SPIFFS.begin(true)){
      Serial.println("Error mounting SPIFFS");
  if (!SD.begin(5)) {
    Serial.println("Error mounting SD card");
  Serial.println("Initializations done");
  CreateFile(IsSD, "r");
  CreateFile(IsSD, "a");
  CreateFile(IsSD, "w");
  CreateFile(IsSPIFFS, "r");
  CreateFile(IsSPIFFS, "a");
  CreateFile(IsSPIFFS, "w");
Here are the Raw results
Initializing ...
Initializing SPIFF
File on : SD card
  >> creation
     Mode : r
     Was existing     : yes
[E][vfs_api.cpp:64] open(): /sd/Test.txt does not exist
no
  << result is : OK (File == 0)
File on : SD card
  >> creation
     Mode : a
     Was existing     : no
     Had been created : yes
  << result is : OK
    Position       : 0
    Available data : FEFEFEFE
  << result is : NOK !!!!!
    Position       : 15
    Available data : 0
  << result is : OK
File on : SD card
  >> creation
     Mode : w
     Was existing     : yes
  << result is : OK
    Position       : 0
    Available data : F
    Position       : 15
    Available data : 0
  << result is : OK
File on : SPIFFS
  >> creation
     Mode : r
     Was existing     : yes
     Had been created : no
  << result is : NOK !!!!! (File != 0)
File on : SPIFFS
  >> creation
     Mode : a
     Was existing     : no
  << result is : OK
    Position       : 0
    Available data : 3FFB20F4
    Position       : 15
    Available data : -15
File on : SPIFFS
  >> creation
     Mode : w
     Was existing     : yes
  << result is : OK
    Position       : 0
    Available data : 3FFB9978
    Position       : 15
ESPfri2
Postby ESPfri2 » Mon May 13, 2019 1:55 pm
summary
Initializing SPIFF
Support  Mode     Open         Size Position  Available     Size Position  Available
SD card  r        OK
SD card  a        OK            NOK       OK        NOK       OK       OK         OK
SD card  w        OK            NOK       OK        NOK       OK       OK         OK
SPIFFS   r        NOK
SPIFFS   a        OK            NOK       OK        NOK      NOK       OK        NOK
SPIFFS   w        OK            NOK       OK        NOK      NOK       OK        NOK
Results :
SD card  r        0
SD card  a        1               0        0          0        f        f          0
SD card  w        1               f        0         15        f        f          0
SPIFFS   r        1
SPIFFS   a        1        3ffb9978        0 1073453432        0        f        -15
SPIFFS   w        1        3ffb9978        0 1073453432        0        f        -15
Expected :
SD card  r        0
SD card  w        1               0        0          0        f        f          0
SPIFFS   r        0
SPIFFS   a        1               0        0          0        f        f          0
SPIFFS   w        1               0        0          0        f        f          0
ESPfri2
Re: open and Files information do not complying with Posix specifications
Postby ESPfri2 » Fri May 17, 2019 7:59 am
New results :
Initializing ...
Initializing SPIFF
Running tests with a non existing file on :
   SD card :  r a w r+ a+ w+
   SPIFFS :  r a w r+ a+ w+
Running tests with a existing empty file on :
Running tests with a existing non empty file on :
With a file non existing
                           Just after open            After first write
Posix   r       0        0        0          0        0        0          0
Posix   a       1        0        0          0        f        f          0
Posix   w       1        0        0          0        f        f          0
Posix   r+      0        0        0          0        0        0          0
Posix   a+      1        0        0          0        f        f          0
Posix   w+      1        0        0          0        f        f          0
SD card r       0        0        0          0        0        0          0
SD card a       1 3ffb9978        0 1073453432        f        f          0
SD card r+      0        0        0          0        0        0          0
SD card a+      1        f        0         15        f        f          0
SD card w+      1        f        0         15        f        f          0
SPIFFS  r       1        0        0          0        0        0          0
SPIFFS  a       1        f        0         15        0        f        -15
SPIFFS  w       1        f        0         15        0        f        -15
SPIFFS  r+      1        f        0         15        f        f          0
SPIFFS  a+      1        f        f          0        f       1e        -15
SPIFFS  w+      1       1e        0         30        0        f        -15
With a file existing empty
Posix   r       1        0        0          0        0        0          0
Posix   r+      1        0        0          0        f        f          0
SD card r       1        0        0          0        0        0          0
SD card r+      1        0        0          0        f        f          0
SD card a+      1        0        0          0        f        f          0
SD card w+      1        0        0          0        f        f          0
SPIFFS  a       1        0        0          0        0        f        -15
SPIFFS  w       1        0        0          0        0        f        -15
SPIFFS  r+      1        0        0          0        0        f        -15
SPIFFS  a+      1        0        0          0        0        f        -15
SPIFFS  w+      1        0        0          0        0        f        -15
With a file existing non empty
Posix   r       1        f        0         15        f        f          0
Posix   a       1        f        f          0       1e       1e          0
Posix   r+      1        f        f          0       1e       1e          0
Posix   a+      1        f        f         15       1e       1e          0
SD card r       1        f        0         15        f        0         15
SD card a       1        f        f          0       1e       1e          0
SD card r+      1        f        0         15        f        f          0
SD card a+      1        f        f          0       1e       1e          0
SPIFFS  r       1        f        0         15        f        0         15
SPIFFS  a       1        f        f          0        f       1e        -15
SPIFFS  w+      1        f        0         15        0        f        -15
new test
#include <FS.h>
#include <SD.h>
#include <errno.h>
 * source : http://man7.org/linux/man-pages/man3/fopen.3.html
       r      Open text file for reading.  The stream is positioned at the
              beginning of the file.
       r+     Open for reading and writing.  The stream is positioned at the
       w      Truncate file to zero length or create text file for writing.
              The stream is positioned at the beginning of the file.
       w+     Open for reading and writing.  The file is created if it does
              not exist, otherwise it is truncated.  The stream is
       a      Open for appending (writing at end of file).  The file is
              created if it does not exist.  The stream is positioned at the
              end of the file.
       a+     Open for reading and appending (writing at end of file).  The
              file is created if it does not exist.  Output is always
              appended to the end of the file.  POSIX is silent on what the
              initial read position is when using this mode.  For glibc, the
              initial file position for reading is at the beginning of the
              file, but for Android/BSD/MacOS, the initial file position for
              reading is at the end of the file.
from : https://pubs.opengroup.org/onlinepubs/009695399/functions/fopen.html
r or rb
    Open file for reading.
w or wb
    Truncate to zero length or create file for writing.
a or ab
    Append; open or create file for writing at end-of-file.
r+ or rb+ or r+b
    Open file for update (reading and writing).
w+ or wb+ or w+b
    Truncate to zero length or create file for update.
a+ or ab+ or a+b
    Append; open or create file for update, writing at end-of-file.
#define _BUFFERMAX 128
static char _Buffer[_BUFFERMAX]="";
void sprintln ( const char * format, ... )
  va_list args;
  va_start (args, format);
  vsnprintf (_Buffer, _BUFFERMAX, format, (va_list)args);
  Serial.println (_Buffer);
  va_end (args);
void sprint ( const char * format, ... )
  va_list args;
  Serial.print (_Buffer);
  va_end (args);
enum testtype {NEF, EEF, ENF};
char *testname[] = {"non existing", "existing empty", "existing non empty", NULL};
int fsmounted[] = { 0, 0};
char *fsname[] = {"SD card", "SPIFFS", NULL};
char *RES[] = {"OK", "NOK"};
char CFilename[] = "/TesT.txt";
struct Res_t {
  int open;
  size_t siz;
  size_t pos;
  int ava;
  size_t sizw;
  size_t posw;
  int avaw;
} *Rest;
#define L strlen(c15)
#define D 2*strlen(c15)
struct Test_t {
  const char *Mode;
  struct Res_t Exp[3];    // [NEF, EEF, ENF]
  struct Res_t Res[2][3]; // [SD, SPIFFS][NEF, EEF, ENF]
} Tests[] = {
  //       O S P A S P A
  {"r",  {{0,0,0,0,0,0,0},
          {1,0,0,0,0,0,0},
          {1,L,0,L,L,L,0}}},
  {"a",  {{1,0,0,0,L,L,0},
          {1,0,0,0,L,L,0},
          {1,L,L,0,D,D,0}}},
  {"w",  {{1,0,0,0,L,L,0},
          {1,0,0,0,L,L,0},
          {1,0,0,0,L,L,0}}},
  {"r+", {{0,0,0,0,0,0,0},
          {1,0,0,0,L,L,0},
          {1,L,L,0,D,D,0}}},
  {"a+", {{1,0,0,0,L,L,0},
          {1,0,0,0,L,L,0},
          {1,L,L,L,D,D,0}}},
  {"w+", {{1,0,0,0,L,L,0},
          {1,0,0,0,L,L,0},
          {1,0,0,0,L,L,0}}},
  {NULL}
File CFile;
void RunTest(int FST, int Test, int Mode) {
  struct Res_t *Res;
  // if file exist erase it
  if (FST == IsSD)
  else
  // if file should exist create it
  if ( Test == EEF || Test == ENF ) {
    if (FST == IsSD)
      CFile = SD.open(CFilename, "w");
    else
      CFile = SPIFFS.open(CFilename, "w");
    // if file should not be empty
    if ( Test == ENF)
      CFile.write((const uint8_t*)c15, L);
    CFile.flush();
    CFile.close();
  if (FST == IsSD)
    CFile = SD.open(CFilename, Tests[Mode].Mode);
  else
    CFile = SPIFFS.open(CFilename, Tests[Mode].Mode);
  Res = &Tests[Mode].Res[FST][Test];
  Res->open = CFile;
  if (!Res->open)
    return;
  Res->siz = CFile.size();
  Res->pos = CFile.position();
  Res->ava = CFile.available();
  CFile.flush();
  Res->sizw = CFile.size();
  Res->posw = CFile.position();
  Res->avaw = CFile.available();
  CFile.close();
  Serial.begin(9600);
  while (!Serial) {}
  delay(3000);
  if (!SD.begin(5)) {
    Serial.print("Error mounting SD card");
    Serial.println(strerror(errno));
  } else
    fsmounted[IsSD] = 1;
  }else
    fsmounted[IsSPIFFS] = 1;
  sprintln("----");
  int t=0,f=0,m=0;
  while (testname[t]) {
    sprintln("Running tests with a %s file on :", testname[t]);
    f=0;
    while (fsname[f]) {
      sprint("   %s : ", fsname[f]);
      if (fsmounted[f]) {
        m=0;
        while(Tests[m].Mode) {
          sprint(" %s", Tests[m].Mode);
          RunTest(f, t, m); //Tests[m].Mode, &Tests[m].Res[f][t]);
          m++;
        sprintln("");
      } else
        sprintln("not mounted");
      f++;
    t++;
  sprintln("----");
  t=0,f=0,m=0;
    sprintln("-------------");
    sprintln("With a file : %s", testname[t]);
    f=0;
    sprintln("%-7s %-4s %4s %28s %28s", "", "", "", "Just after open    ", "After first write    ");
    sprintln("%-7s %-4s %4s %8s %8s %10s %8s %8s %10s", "Support", "Mode", "Open", "Size", "Position", "Available", "Size", "Position", "Available");
    m=0;
      sprint("%-7s %-4s ", "Posix", Tests[m].Mode);
      Rest = &Tests[m].Exp[t];
      sprintln("%4x %8x %8x %10d %8x %8x %10d", Rest->open, Rest->siz, Rest->pos, Rest->ava, Rest->sizw, Rest->posw, Rest->avaw);
      m++;
    while (fsname[f]) {
      if (fsmounted[f]) {
        m=0;
          sprint("%-7s %-4s ", fsname[f], Tests[m].Mode);
          Rest = &Tests[m].Res[f][t];
          m++;
      } else
      f++;
    t++;
      sprintln("%-8s %-8s %-8s %8s %8s %10s %8s %8s %10s", "Support", "Mode", "Open", "Size", "Position", "Available", "Size", "Position", "Available");
    while (ExNEF[i].Mode) {
      RunNEF(IsSD, ExNEF[i].Mode, &Tests[i]. );
      fsname[Tests[i].FS], Tests[i].Mode,
      (Tests[i].result.open == Tests[i].expect.open? RES[0] : RES[1]),
      (Tests[i].result.siz == Tests[i].expect.siz? RES[0] : RES[1]),
      (Tests[i].result.pos == Tests[i].expect.pos? RES[0] : RES[1]),
      (Tests[i].result.ava == Tests[i].expect.ava? RES[0] : RES[1]),
      (Tests[i].result.sizw == Tests[i].expect.sizw? RES[0] : RES[1]),
      (Tests[i].result.posw == Tests[i].expect.posw? RES[0] : RES[1]),
      (Tests[i].result.avaw == Tests[i].expect.avaw? RES[0] : RES[1]));
  Serial.println("Raw results :");
  i=0;
  while (Tests[i].Mode) {
    CreateFile(&Tests[i]);
    sprintln("%-8s %-8s %-8x %8x %8x %10d %8x %8x %10d",
      Tests[i].result.open,
      Tests[i].result.siz, Tests[i].result.pos, Tests[i].result.ava,
      Tests[i].result.sizw, Tests[i].result.posw, Tests[i].result.avaw);
      i++;
  Serial.println("Expected results :");
  i=0;
      Tests[i].expect.open,
      Tests[i].expect.siz, Tests[i].expect.pos, Tests[i].expect.ava,
      Tests[i].expect.sizw, Tests[i].expect.posw, Tests[i].expect.avaw);
    i++;
  Serial.println("----------------------------------------------");
  Serial.println("Work with a pre-existing empty file on the FS :");
  i=0;
  while (ETests[i].Mode) {
    ExistingFile(&ETests[i]);
      fsname[ETests[i].FS], ETests[i].Mode,
      ETests[i].result.open,
      ETests[i].result.siz, ETests[i].result.pos, ETests[i].result.ava,
      ETests[i].result.sizw, ETests[i].result.posw, ETests[i].result.avaw);
      i++;
  Serial.println("--------------------------------------------------");
  Serial.println("Work with a pre-existing non-empty file on the FS :");
  i=0;
  while (EnTests[i].Mode) {
    ExistingNeFile(&EnTests[i]);
      fsname[EnTests[i].FS], EnTests[i].Mode,
      EnTests[i].result.open,
      EnTests[i].result.siz, EnTests[i].result.pos, EnTests[i].result.ava,
      EnTests[i].result.sizw, EnTests[i].result.posw, EnTests[i].result.avaw);
      i++;
muller59
Re: open and Files information do not comply with Posix specifications
Postby muller59 » Thu Jul 18, 2019 12:03 pm
After hitting the brick wall one too many times, i googled my problem and found this post.
i also found another post on github that related to this.
I thought you would be interested in the answer from the developer of esp32 SPIFFS
https://github.com/espressif/arduino-esp32/issues/681
regards,
Rob
ESPfri2
Postby ESPfri2 » Thu Jul 18, 2019 3:04 pm
thanks !
I will look at it
Users browsing this forum: alanesq and 9 guests
