I have noticed that using the native FPU division instructions leads to unexpected results when dividing two floating numbers of significantly different exponents.
It seems that if a division operator is used in C code, gcc inserts a call to __divsf3() which does not use the native FPU division instructions but instead relies on software implementation and gives the correct result. As I am working on computationally intensive DSP code, performance is really important to me and I would like to use the native instructions instead. Using the FPU instruction sequence for division as documented in the ISA Reference manual and implemented in divsf() : https://github.com/espressif/esp-idf/bl ... /test_fp.c however leads to wrong results (typically 0.0) when the two exponents differ a lot. The FPU division should however be IEEE compliant according to documentation.
An example code:
float x = 24e9;
float y = 4;
printf("C: %.2f/%.2f = %.2f\n", x,y, x/y);
printf("ASM: %.2f/%.2f = %.2f\n", x,y, divsf(x,y));
x = 17;
y = 4;
C: 24000000000.00/4.00 = 6000000000.00
ASM: 24000000000.00/4.00 = 0.00
C: 17.00/4.00 = 4.25
ASM: 17.00/4.00 = 4.25
Thank you very much!
