A You Tube video on the ESP32 and Pulse Width Modulation (PWM):
https://www.youtube.com/watch?v=rarE-WI_Y0A
Illustrates LED dimming and servo motor control.
[Video] ESP32 - Pulse Width Modulation
Re: [Video] ESP32 - Pulse Width Modulation
Hi kolban, you are really doing a greate job with all your videos!!!
I wonder if you can help me in the right direction. I'm trying to control a servo, and have succeded to complie and run your servoSweep example.
But I cannot for the world figure out how to move the servo to a certain point, as you descibe in the video (and document)
I have tried to read all there is about PWM and changing values in your code, but no success. Can you give any tips or example how this could be accomplished.
A servo is controlled by a PWM signal. Commonly they have a period of 20ms. That means that the signal repeats every 20ms. However, common servo encoding uses the first couple of ms to control the position. If we imagine a PWM signal as being broken into two parts ... the time that the signal is high and the time that the signal is low.
Commonly:
if the signal is high for 1 ms and low for 19 ms, then the servo turns 100% in one direction.
if the signal is high for 2 ms and low for 18 ms, then the servo turns 100% in the other direction.
if the signal is high for 1.5 ms and low for 18.5ms, then servo turns 50% of the direction.
... and so on ...
So algorithmically ... if the signal is high for 1 + n/180 then the servo turns n degrees (based on granularity of the servo device itself).
Commonly:
... and so on ...
Thanks for the answer, I will try again and see if I succeed
Users browsing this forum: No registered users and 71 guests
