Cant Access EEPROM over WIFI Handler
maxbayne
Postby maxbayne » Fri May 31, 2019 10:15 am
hello to every body
i have ESP32 - WROOM
i use it as web server
it run perfect as server but when i try to access EEPROM to write some value in it the system crash
i define server settings as it
#include <WiFiClient.h>
#include <ESP32WebServer.h>
#include <WiFi.h>
#include <ESPmDNS.h>
ESP32WebServer server(80);
void setup()
EEPROM.begin(1024);
Serial.println();
    Serial.print("Connecting to ");
    Serial.println("myrouterSSID");
    //Try To Connect to Wifi
    WiFi.begin("myrouterSSID", "myRouterPSW");
    //Loop until Connecting To Wifi Network
    while (WiFi.status() != WL_CONNECTED)
      delay(500);
      Serial.print(".");
    //when connecting to wifi network successfully
    if (WiFi.status() == WL_CONNECTED)
      Serial.println("");
      Serial.println("WiFi connected.");
      Serial.println("IP address: ");
    //try to register dns for this node
    while (!MDNS.begin("esp32"))
      Serial.println("Error on Setting up MDNS");
      delay(1);
    //register http request events ----------
   //GET: http://192.168.1.120/set/timer?duration=5000
    server.on("/set/timer", []()
      int duration = atoi(server.arg(0).c_str());
      EEPROM.writeInt(100, duration);
      EEPROM.commit();
      server.send(200, "text/plain", "Done");
     server.begin();
    Serial.println("HTTP Server Started : ");
    Serial.print(secure.Dns);
    Serial.println("----------------------------");
    Serial.println("");
void Loop()
server.handleClient();
when i try to make http request from browser as GET
i got this error (i use visual studio code with PlatfromIO)
Guru Meditation Error: Core  1 panic'ed (Cache disabled but cached memory region accessed)
Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x40150064: bad00bad bad00bad bad00bad
Guru Meditation Error: Core  1 panic'ed (IlleGuru Meditation Error: Core  1 panic'ed (Unhandled debug exception)
Debug exception reason: Stack canary watchpoint triggered ()
Guru Meditation Error: Core  1 panic'ed (Guru Meditation Error: Core  1 panic'ed (Double exception)
how can i fix this error ?
Users browsing this forum: No registered users and 40 guests
