I2C use by ULP and CPU
sch0bert
Postby sch0bert » Tue Jun 04, 2019 5:59 pm
I'm trying to use the same pins for I2C in ULP and CPU (active mode) but when I try to use it, nothing works. Is it possible to have both configured to use the same pins or should I use different ones?
I'm using SDA pin as the 33 and SCL as the 32. Also I tested both in separated programs and they worked, no when I put them together.
Regards,
Pascal.
WiFive
Re: I2C use by ULP and CPU
Postby WiFive » Tue Jun 04, 2019 6:47 pm
If they work in separate programs they should work together, just not at the same time.
sch0bert
Postby sch0bert » Tue Jun 04, 2019 10:29 pm
Ok, will then debug further to see what's going on. Thanks!
Users browsing this forum: Baidu [Spider], PetalBot and 2 guests
