No "Ready" Prompt after loading ESP32_AT_V1.1.3
Posted: Fri Jun 07, 2019 5:50 pm
by jerry.hubbell
I have been able to load the AT firmware ESP32_AT_V1.1.3 but when it boots, It stops in the middle (I think) and I never get the ready prompt. Here is the log:
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5656
load:0x40078000,len:0
ho 12 tail 0 room 4
load:0x40078000,len:13844
entry 0x40078fc4
I (31) boot: ESP-IDF v3.0.7 2nd stage bootloader
I (31) boot: compile time 09:04:31
I (31) boot: Enabling RNG early entropy source...
I (35) boot: SPI Speed : 40MHz
I (40) boot: SPI Mode : DIO
I (44) boot: SPI Flash Size : 4MB
I (48) boot: Partition Table:
I (51) boot: ## Label Usage Type ST Offset Length
I (59) boot: 0 phy_init RF data 01 01 0000f000 00001000
I (66) boot: 1 otadata OTA data 01 00 00010000 00002000
I (73) boot: 2 nvs WiFi data 01 02 00012000 0000e000
I (81) boot: 3 at_customize unknown 40 00 00020000 000e0000
I (88) boot: 4 ota_0 OTA app 00 10 00100000 00180000
I (96) boot: 5 ota_1 OTA app 00 11 00280000 00180000
I (103) boot: End of partition table
I (108) boot: No factory image, trying OTA 0
I (113) esp_image: segment 0: paddr=0x00100020 vaddr=0x3f400020 size=0x20614 (132628) map
I (168) esp_image: segment 1: paddr=0x0012063c vaddr=0x3ffc0000 size=0x02d7c ( 11644) load
I (173) esp_image: segment 2: paddr=0x001233c0 vaddr=0x40080000 size=0x00400 ( 1024) load
I (175) esp_image: segment 3: paddr=0x001237c8 vaddr=0x40080400 size=0x0c848 ( 51272) load
I (205) esp_image: segment 4: paddr=0x00130018 vaddr=0x400d0018 size=0xdfc80 (916608) map
I (526) esp_image: segment 5: paddr=0x0020fca0 vaddr=0x4008cc48 size=0x02504 ( 9476) load
I (531) esp_image: segment 6: paddr=0x002121ac vaddr=0x400c0000 size=0x00064 ( 100) load
I (542) boot: Loaded app from partition at offset 0x100000
I (542) boot: Disabling RNG early entropy source...
1.1.3
I (663) wifi: wifi firmware version: 703e53b
I (664) wifi: config NVS flash: enabled
I (664) wifi: config nano formating: disabled
I (674) wifi: Init dynamic tx buffer num: 32
I (674) wifi: Init data frame dynamic rx buffer num: 32
I (674) wifi: Init management frame dynamic rx buffer num: 32
I (680) wifi: wifi driver task: 3ffdee34, prio:23, stack:3584
I (685) wifi: Init static rx buffer num: 10
I (688) wifi: Init dynamic rx buffer num: 32
I (693) wifi: wifi power manager task: 0x3ffe369c prio: 21 stack: 2560
I (734) wifi: mode : softAP (24:6f:28:da:af:61)
I (741) wifi: mode : sta (24:6f:28:da:af:60) + softAP (24:6f:28:da:af:61)
I (745) wifi: mode : softAP (24:6f:28:da:af:61)
I (748) wifi: set country: cc=CN schan=1 nchan=13 policy=1
That is where it stops. Shouldn't I see the "ready" prompt as stated in the AT command manual?
Jerry Hubbell
Re: No "Ready" Prompt after loading ESP32_AT_V1.1.3
Posted: Tue Aug 18, 2020 2:33 am
by els_intr_assi
I am having exactly same problem with you
have you done with that?
Posted: Tue Aug 18, 2020 8:08 am
by krzychb
Hi els_intr_assi,
The log posted by jerry.hubbell shows up on "Download port", the AT ready prompt shows up on a second port called "AT port" , see https://docs.espressif.com/projects/esp ... ction.html
