Guru Meditation Error: Cache disabled but cached memory region accessed
Posted: Mon Jun 10, 2019 5:06 am
by raduangelescu
I have piece of code that after running a few hours (3-5 hours) gives me the above kernel panic "Guru Meditation Error: Cache disabled but cached memory region accessed" . The callstack does not tell me anything (it doesn't dump much).
This is the culprit code (if I remove digitalWrite from timer ISR it no longer crashes, but that could be because the whole code gets optimized and doesn't execute).
Code: Untitled.cpp Select all
#pragma once
#include <Settings.h>
DRAM_ATTR volatile unsigned long long inctimer = 0;
DRAM_ATTR volatile bool onlyLow = false;
DRAM_ATTR volatile unsigned char g_state = 0;
DRAM_ATTR volatile const unsigned long long divizor = 10;
DRAM_ATTR volatile unsigned long startZCMicros = 0;
DRAM_ATTR volatile unsigned long long intervalZCMicros = 10000/divizor; // 50 hz
DRAM_ATTR volatile unsigned long long pulseLengthMicros = 300/divizor;
DRAM_ATTR volatile unsigned long long pulseBeginMicros = LONG_MAX;
DRAM_ATTR volatile unsigned long long pulseOffsetZCMicros = LONG_MAX;
void IRAM_ATTR OnTimerHeater()
if(onlyLow)
digitalWrite(CONTROL_PIN, LOW);
return;
volatile long currentMicros = micros()/divizor;
volatile long localPulseBeginMicros = pulseBeginMicros + pulseOffsetZCMicros;
volatile long localPulseEndMicros = pulseBeginMicros + pulseOffsetZCMicros + pulseLengthMicros;
if(currentMicros >= localPulseEndMicros)
else if(currentMicros >= localPulseBeginMicros)
digitalWrite(CONTROL_PIN, HIGH);
void IRAM_ATTR OnZeroCrossHeater()
volatile const long current_micros = micros()/divizor;
volatile int i = 0;
if(digitalRead(ZERO_CROSS_PIN) == LOW)
for (; i < 1000; ++i) {}
if(digitalRead(ZERO_CROSS_PIN) == HIGH)
return;
else
return;
if(current_micros - startZCMicros < 100)
return;
switch(g_state)
case 0:
startZCMicros = current_micros;
break;
case 1:
intervalZCMicros = current_micros - startZCMicros;
break;
g_state++;
if(g_state > 1)
g_state = 0;
if(intervalZCMicros != -1)
pulseBeginMicros = current_micros;
class Heater
double m_prev_value = 0.0;
hw_timer_t* m_timer = nullptr;
public:
Heater()
void setup()
pinMode(CONTROL_PIN, OUTPUT);
pinMode(ZERO_CROSS_PIN, INPUT_PULLUP);
m_timer = timerBegin(0, 80 * divizor, true);
// per microsecond
timerAttachInterrupt(m_timer, &OnTimerHeater, true);
timerAlarmWrite(m_timer, 1, true);
timerAlarmEnable(m_timer);
attachInterrupt(ZERO_CROSS_PIN, OnZeroCrossHeater, RISING);
void set(double value)
if(value > 50.0)
value = 50.0;
if(value < 0.0)
value = 0.0;
unsigned long long localinterval = intervalZCMicros;
if(m_prev_value == value)
return;
unsigned long long localCalculation = 0;
if(abs(value) < 0.01 )
localCalculation = LONG_MAX;
onlyLow = true;
else
onlyLow = false;
localCalculation = (long long)((100.0 - value) * 0.01 * localinterval) - pulseLengthMicros;
if(localCalculation < 0)
pulseOffsetZCMicros = localCalculation;
Serial.print("heating with ");
Serial.print(value);
Serial.println("--");
m_prev_value = value;
void loop()
I researched the problem but I can't understand what is the cache that is accessed.. I made everything volatile and in DRAM... (I don't use SPI , only I2C)
Cheers,
Radu
Re: Guru Meditation Error: Cache disabled but cached memory region accessed
Posted: Mon Jun 10, 2019 5:58 pm
by raduangelescu
As a memory "dump" I only get : Memory dump at 0x40161aec: bad00bad bad00bad bad00bad
Posted: Tue Jun 11, 2019 12:53 am
by Sprite
This happens if you call a function that is not in IRAM (perhaps digitalWrite?) while the flash cache is disabled because the ESP32 needs to write to flash. However, normally ESP-IDF disables interrupts when it accesses flash unless you specifically tell it not to... I don't know if the Arduino code also does this, though.
Posted: Tue Oct 01, 2019 10:48 am
by ningappa BS
Hi ESP_Sprite,
I used GPIO.out_w1tc = (1 << 19) instred of gpio_set_level(GPIO_NUM_19, 0) but still I'm getting error Guru Meditation Error: Cache disabled but cached memory region accessed and I did not get SPI_MASTER_ISR_IN_IRAM in menuconfig and also in sdkconfig. Please help me to solve problem.
thanks
