How to receive MQTT messages after deep sleep?
Maxyct
Postby Maxyct » Mon Jun 10, 2019 11:28 pm
Hi guys,
is it possible to subscribe to a MQTT topic and collect messages every time the ESP32 wakes up from deep sleep mode?
I'm using Arduino IDE and loop function is not used in deep sleep mode and cannot understand where I should insert the client.loop() call: in the setup?
I'm using this library: https://pubsubclient.knolleary.net/api.html
Thanks,
Max
danwat
Re: How to receive MQTT messages after deep sleep?
Postby danwat » Sat Jun 15, 2019 5:57 am
Hi Max,
The thing to remember is, when using the arduino framework and deep sleeping, your sketch only runs the setup() section and never runs the loop() part.
So, one (pseudocode) option would look something like this
bool readyToSleep=false;
  // I'm awake from sleep
  esp_sleep_enable_timer_wakeup(100000000);
  setup_networking();
  subscribe_topics();
  while(!readyToSleep){
     do_cool_things();
     client.loop();  //Ensure we've sent & received everything
  esp_deep_sleep_start();
void loop(){
  // Usually won't get here
at some point in do_cool_things() you'd have to decide you'd been awake long enough (maybe a counter) , and set readyToSleep=true;
the code will call client.loop() one last time and then go back to sleep.
cheers,
Dan
kian79
Postby kian79 » Wed Jul 10, 2019 8:39 am
Has the problem been solved? Because I am having the same issues. I am following the pseudocode suggested by @danwat, but it is still not working.
I am using the WebSocket UI inside CloudMQTT to publish some data to a topic. If the message is published when the ESP32 is sleeping, after the ESP32 wakes up, it doesn't pull this published data from the subscribed topic.
#include <WiFi.h>
#include <PubSubClient.h>
#define uS_TO_S_FACTOR 1000000  /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP  30        /* Time ESP32 will go to sleep (in seconds) */
RTC_DATA_ATTR int bootCount = 0;
const char* ssid = "XXXXXXXX";
const char* password = "XXXXXXXXXXXXX";
const char* mqttServer = "postman.cloudmqtt.com";
const int mqttPort = XXXXX
const char* mqttUser = "XXXXXXXX;
const char* mqttPassword = "XXXXXXXXXX";
String temp_str;
char temp[50];
WiFiClient espClient;
PubSubClient client(espClient);
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived in topic: ");
  Serial.println(topic);
  Serial.print("Message:");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  Serial.println();
  Serial.println("-----------------------");
  WiFi.begin(ssid, password);
    delay(500);
    Serial.println("Connecting to WiFi..");
  Serial.println("Connected to the WiFi network");
  client.setServer(mqttServer, mqttPort);
  client.setCallback(callback);
  while (!client.connected()) {
    Serial.println("Connecting to MQTT...");
    if (client.connect("ESP32Client", mqttUser, mqttPassword )) {
      Serial.println("connected");
      Serial.print("failed with state ");
      Serial.print(client.state());
      delay(2000);
  client.subscribe("esp/test");
  for(int i=0;i<10; i++)
   delay(100);
  Serial.print("Going to Sleep...");
  esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
ed2000
Postby ed2000 » Sun Jan 26, 2020 11:46 am
I know it has been a while, but this worked for me on an ESP8266.
essential though that you persist the MQTT message so it is still there when your esp wakes up
https://wp.me/p2ffrb-11V
Users browsing this forum: No registered users and 41 guests
