esp32AP getrequest
mehrdadco
esp32AP getrequest
Postby mehrdadco » Tue Jun 11, 2019 9:15 am
I started a project that requires communication between esp32 as an AP and pc client. I send the HTML code but there is no idea to receive an answer .looking for any clue or example to receive a data and can see it in the serial monitor.
it's my HTML code
Code: Untitled.c Select all
const char *ssid = "MyESP";
const char HTML[] PROGMEM = "<script language=\"JavaScript\">function formToJson(form){var pass=form.pass.value;var ssid=form.ssid.value;var jsonFormInfo=JSON.stringify({pass:pass, ssid: ssid});window.alert('OK');}</script> <form onSubmit=\"event.preventDefault(); formToJson(this);\"> <label class=\"label\">Network Name</label> <input type=\"text\" name=\"ssid\"/> <label>Password</label> <input type=\"text\" name=\pass/> <input type=\"submit\" value=\"Submit\"></form>";
AsyncWebServer server(80);
WiFi.softAP(ssid);
Serial.println();
Serial.print("IP address: ");
Serial.println(WiFi.softAPIP());
server.on("/Cfig", HTTP_GET, [](AsyncWebServerRequest *request) {
request->send(200, "text/html", HTML);});
server.begin();
HTTPClient http;
http.begin("http://192.168.1.87");
http.addHeader("Content-Type", "text/plain");
int httpResponseCode = http.POST("POSTING from ESP32");
if (httpResponseCode > 0) {
String response = http.getString();
Serial.println(httpResponse);
Serial.println(response); }
else {Serial.print("Error on sending POST: ");
Serial.println(httpResponse);}
http.end();}
iwant to save ssid ,pass in esp32
Re: esp32AP getrequest
Postby Sprite » Tue Jun 11, 2019 9:16 am
Moved to Arduino, as it seems to be for the webserver for that platform.
