Does anyone know how to reload the factory image back on the dev kit? I would like to restore it back to stock, but have not been able to find the program/files for it.
Thanks,
Jeff
ESP32 Azure IoT Kit
fivdiAtESP32
Re: ESP32 Azure IoT Kit
I'm not sure if it's exactly the same but the esp32_azure_iot_kit example in the esp-iot-solution project look like the demo that runs on a stock ESP32-Azure IoT Kit.
See https://github.com/espressif/esp-iot-so ... adme_en.md
Thank you. I wish it was more obvious to a beginner. I was able to rebuild it and get it installed on the board.I'm not sure if it's exactly the same but the esp32_azure_iot_kit example in the esp-iot-solution project look like the demo that runs on a stock ESP32-Azure IoT Kit.
HiThank you. I wish it was more obvious to a beginner. I was able to rebuild it and get it installed on the board.I'm not sure if it's exactly the same but the esp32_azure_iot_kit example in the esp-iot-solution project look like the demo that runs on a stock ESP32-Azure IoT Kit.
which problems you had?
if you are missing document or redame (en) or readme (cn) .
allways backup factory fw that comes out of the box if you flash with your own,
so you can restore allways to factory
1MB Flash
esptool.py --p COM5 --baud 115200 read_flash 0x00000 0x100000 Backup_1MB.bin
2MB Flash
esptool.py --p COM5 --baud 115200 read_flash 0x00000 0x200000 Backup_2MB.bin
4MB Flash
esptool.py --p COM5 --baud 115200 read_flash 0x00000 0x400000 Backup_4MB.bin
8MB Flash
esptool.py --p COM5 --baud 115200 read_flash 0x00000 0x800000 Backup_8MB.bin
16MB Flash
esptool.py --p COM5 --baud 115200 read_flash 0x00000 0x1000000 Backup_16MB.bin
32MB Flash
esptool.py --p COM5 --baud 115200 read_flash 0x00000 0x200000 Backup_32MB.binfurther help about esptool you find in redame of the repo
rudi
pollock694
The github link has expired. I need the factory image too. Do you know where I can get it?Does anyone know how to reload the factory image back on the dev kit? I would like to restore it back to stock, but have not been able to find the program/files for it.
Thanks,
Jeff
