ESP-WROOM-32 AT commands firmware
wind_energy
hi,
I got the a ESP-WROOM-32 in hope to easy use AT commands to connect our router.
As soon as I got it i`ve checked that I need to put another firmware with AT commands service.
I don`t have now any environment to compile source.
I tryied to download bin file from here: https://github.com/espressif/esp32-at.
Unfortunatelly this link doesn`t work:
You can get AT bin from http://espressif.com/zh-hans/support/do ... d%5B%5D=13
Many thanks for any help.
Best regards,
Pawel
Best regards,
Pawel
Re: ESP-WROOM-32 AT commands firmware
Moved to General Discussion, this does not belong in News. What is your question exactly?
His question is where is the bin file it doesn't seem to be listed in downloads section on espressif.comMoved to General Discussion, this does not belong in News. What is your question exactly?
Ah, missed the bit where the link doesn't work. I'll see if I can poke whoever is responsible.
http://esp32.com/viewtopic.php?f=2&t=1058Ah, missed the bit where the link doesn't work. I'll see if I can poke whoever is responsible.
thanks
Fyi: the AT binary isn't available yet because it isn't production-ready. The current AT firmware is compiled with a non-production version of ESP-IDF; apart from that there's also a bug related to AT+RESTORE that we need to fix. We'll edit the git repo to kill the non-working download link for now; expect a binary somewhere after we release ESP-IDF 2.0.
wind_energy
wind_energy
hi,
The bin file is already done. I`ve gotten it from my supplier of esp modules. Check attachments. Change file name ESP32_ATcommand.bin.rar -> ESP32_ATcommand.bin. enjoy.
Regards,
Pawel
Regards,
Pawel
- ESP32_ATcommand.bin.rar
- (837.55 KiB) Downloaded 1967 times
Keep in mind that that is a preliminary version of the binary. We may or may not support bugs in this until the official version comes out.
wind_energy
I`ve downloaded the firmware and there is no response on AT commands.
Any idea what can I do to start communication by AT commands?
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3ffc0008,len:4
load:0x3ffc000c,len:3812
load:0x40078000,len:4748
load:0x40080000,len:260
entry 0x40080034
[0;32mI (27) boot: Espressif ESP32 2nd stage bootloader v. V0.1[0m
[0;32mI (36) boot: compile time 17:17:25[0m
D (42) esp_image: reading image header @ 0x1000[0m
D (49) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff)[0m
D (59) boot: magic e9[0m
D (63) boot: segments 04[0m
D (67) boot: spi_mode 02[0m
D (71) boot: spi_speed 00[0m
D (75) boot: spi_size 01[0m
[0;32mI (79) boot: SPI Speed : 40MHz[0m
[0;32mI (85) boot: SPI Mode : DIO[0m
[0;32mI (91) boot: SPI Flash Size : 2MB[0m
[0;32mI (97) boot: Partition Table:[0m
[0;32mI (103) boot: ## Label Usage Type ST Offset Length[0m
D (114) bootloader_flash: mmu set paddr=00000000 count=1[0m
D (122) boot: mapped partition table 0x8000 at 0x3f408000[0m
D (130) boot: load partition table entry 0x3f408000[0m
D (138) boot: type=1 subtype=1[0m
[0;32mI (143) boot: 0 phy_init RF data 01 01 0000f000 00001000[0m
D (154) boot: load partition table entry 0x3f408020[0m
D (162) boot: type=0 subtype=10[0m
[0;32mI (167) boot: 1 ota_0 OTA app 00 10 00010000 000ea000[0m
D (178) boot: load partition table entry 0x3f408040[0m
D (186) boot: type=1 subtype=2[0m
[0;32mI (190) boot: 2 nvs WiFi data 01 02 000fa000 00016000[0m
D (202) boot: load partition table entry 0x3f408060[0m
D (209) boot: type=0 subtype=11[0m
[0;32mI (214) boot: 3 ota_1 OTA app 00 11 00110000 000ea000[0m
D (226) boot: load partition table entry 0x3f408080[0m
D (233) boot: type=1 subtype=0[0m
[0;32mI (238) boot: 4 otadata OTA data 01 00 001fd000 00003000[0m
D (249) boot: load partition table entry 0x3f4080a0[0m
D (257) boot: type=ff subtype=ff[0m
[0;32mI (262) boot: End of partition table[0m
D (269) bootloader_flash: mmu set paddr=001f0000 count=1[0m
[0;32mI (277) boot: Loading app partition at offset 00010000[0m
D (286) esp_image: reading image header @ 0x10000[0m
D (293) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)[0m
D (303) esp_image: reading 9 image segments[0m
D (396) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (396) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00020000)[0m
D (400) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (496) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (538) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00030000)[0m
D (538) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (542) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (563) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00030000)[0m
D (564) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (573) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (585) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00030000)[0m
D (594) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (604) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (647) bootloader_flash: mmu set block paddr=0x00040000 (was 0x00030000)[0m
D (734) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00040000)[0m
D (768) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00050000)[0m
D (768) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (772) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (782) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (793) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00050000)[0m
D (803) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (814) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (824) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (887) bootloader_flash: mmu set block paddr=0x00060000 (was 0x00050000)[0m
D (888) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00060000)[0m
D (891) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (901) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (912) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (922) bootloader_flash: mmu set block paddr=0x00060000 (was 0x00050000)[0m
D (1019) bootloader_flash: mmu set block paddr=0x00070000 (was 0x00060000)[0m
D (1106) bootloader_flash: mmu set block paddr=0x00080000 (was 0x00070000)[0m
D (1192) bootloader_flash: mmu set block paddr=0x00090000 (was 0x00080000)[0m
D (1279) bootloader_flash: mmu set block paddr=0x000a0000 (was 0x00090000)[0m
D (1366) bootloader_flash: mmu set block paddr=0x000b0000 (was 0x000a0000)[0m
D (1453) bootloader_flash: mmu set block paddr=0x000c0000 (was 0x000b0000)[0m
D (1539) bootloader_flash: mmu set block paddr=0x000d0000 (was 0x000c0000)[0m
D (1547) bootloader_flash: mmu set block paddr=0x00010000 (was 0x000d0000)[0m
D (1548) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1554) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (1565) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (1575) bootloader_flash: mmu set block paddr=0x00060000 (was 0x00050000)[0m
D (1586) bootloader_flash: mmu set block paddr=0x000d0000 (was 0x00060000)[0m
D (1596) esp_image: reading checksum block at 0xd1620[0m
D (1604) esp_image: reading image header @ 0x10000[0m
D (1611) bootloader_flash: mmu set block paddr=0x00010000 (was 0x000d0000)[0m
D (1622) boot: bin_header: 233 9 2 1 40080a7c[0m
[0;32mI (1629) boot: segment 0: paddr=0x00010018 vaddr=0x00000000 size=0x0ffe8 ( 65512) [0m
D (1641) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1652) boot: found drom segment, map from 00020010 to 3f400010[0m
[0;32mI (1661) boot: segment 1: paddr=0x00020008 vaddr=0x3f400010 size=0x17978 ( 96632) map[0m
D (1674) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00020000)[0m
D (1684) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1695) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
[0;32mI (1706) boot: segment 2: paddr=0x00037988 vaddr=0x3ffc2960 size=0x02174 ( 8564) load[0m
D (1719) bootloader_flash: mmu set paddr=00030000 count=1[0m
D (1731) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)[0m
D (1738) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1748) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
[0;32mI (1759) boot: segment 3: paddr=0x00039b04 vaddr=0x40080000 size=0x00400 ( 1024) load[0m
D (1772) bootloader_flash: mmu set paddr=00030000 count=1[0m
D (1781) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)[0m
D (1791) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1801) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
[0;32mI (1812) boot: segment 4: paddr=0x00039f0c vaddr=0x40080400 size=0x1c420 (115744) load[0m
D (1825) bootloader_flash: mmu set paddr=00030000 count=3[0m
D (1888) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)[0m
D (1889) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1892) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (1903) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
[0;32mI (1913) boot: segment 5: paddr=0x00056334 vaddr=0x400c0000 size=0x00034 ( 52) load[0m
D (1926) bootloader_flash: mmu set paddr=00050000 count=1[0m
D (1935) bootloader_flash: mmu set block paddr=0x00010000 (was 0xffffffff)[0m
D (1945) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (1956) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (1967) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
[0;32mI (1977) boot: segment 6: paddr=0x00056370 vaddr=0x00000000 size=0x09c98 ( 40088) [0m
D (1990) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00050000)[0m
D (2000) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (2011) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (2021) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (2032) bootloader_flash: mmu set block paddr=0x00060000 (was 0x00050000)[0m
D (2042) boot: found irom segment, map from 00060018 to 400d0018[0m
[0;32mI (2052) boot: segment 7: paddr=0x00060010 vaddr=0x400d0018 size=0x715f8 (464376) map[0m
D (2065) bootloader_flash: mmu set block paddr=0x00010000 (was 0x00060000)[0m
D (2075) bootloader_flash: mmu set block paddr=0x00020000 (was 0x00010000)[0m
D (2086) bootloader_flash: mmu set block paddr=0x00030000 (was 0x00020000)[0m
D (2096) bootloader_flash: mmu set block paddr=0x00050000 (was 0x00030000)[0m
D (2107) bootloader_flash: mmu set block paddr=0x00060000 (was 0x00050000)[0m
D (2117) bootloader_flash: mmu set block paddr=0x000d0000 (was 0x00060000)[0m
[0;32mI (2128) boot: segment 8: paddr=0x000d1610 vaddr=0x50000000 size=0x00008 ( 8) load[0m
D (2141) bootloader_flash: mmu set paddr=000d0000 count=1[0m
D (2149) boot: configure drom and irom and start[0m
D (2156) boot: start: 0x40080a7c[0m
heap:182532
tcpip_task_hdlxxx : 3ffcc234, prio:18,stack:2048
I (2463) wifi: frc2_timer_task_hdl:3ffcdc74, prio:22, stack:2048
I (2472) wifi: pp_task_hdl : 3ffd0514, prio:23, stack:8192
I (2473) wifi: mode : softAP (24:0a:c4:05:e2:71)
dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1)
I (2479) wifi: mode : sta (24:0a:c4:05:e2:70) + softAP (24:0a:c4:05:e2:71)
I (2487) wifi: mode : softAP (24:0a:c4:05:e2:71)
I (485443) wifi: n:1 0, o:1 0, ap:1 1, sta:255 255, prof:1
I (485444) wifi: station: ac:ee:9e:67:d9:b6 join, AID = 1, n, 20
AT
AT
ATWho is online
Users browsing this forum: Applebot, ChatGPT-User, Qwantbot and 1 guest
