ESP32 I2C read issue
Manish Jugran
Postby Manish Jugran » Tue Jun 18, 2019 9:22 am
Hi ,
I am using ADC121C_MQ4_Methane_Gas_Sensor with esp32 but not able to detect I2C address.What would be the I2C scan code for esp32 ?
rodmcm
Re: ESP32 I2C read issue
Postby rodmcm » Thu Jun 20, 2019 9:14 am
The sensor, if it is I2C compatible should have a singular or range of addresses that can be used to read and write to it. If you cannot find this in a manual then search for 'I2C Scanner" this program will register all of the I2C nodes connected.
http://www.ti.com/lit/ds/symlink/adc121c021.pdf
Interfacing ADC121C With Arduino Nano(I2C) - Instructables
Its all out there if you look!
Users browsing this forum: Applebot, Bing [Bot] and 0 guests
