Temperatures WROVER-B & WROVER
sha388
Postby sha388 » Thu Jul 04, 2019 2:11 pm
Hi Everyone,
i would like to ask you which is the difference between the WROVER-B and WROVER esp32 module.
In the appliacation where i use the ESP32, unfortunatly the operative temperature ranges changes from 60 to 75 °C, looking to the WROVER-B datasheet i have a operative temperature range form -40 to 65°C but in the WROVER datasheet i see -40 to 85°C.
My question now is... why there is 2 different temperatures? only because the WROVER -B could be built with a 16MB PSRAM?
Which are the effects if i use the WROVER-B at 75°C? there any effects on the life time cycle? anyone of you have experience using the ESP32 in application where the temperatures are high?
Thanks to everyone in advance!
WiFive
Re: Temperatures WROVER-B & WROVER
Postby WiFive » Fri Jul 05, 2019 7:34 am
Wrover-b uses 3.3v flash and ram. Wrover uses 1.8v. contact sales about industrial temp version.
sha388
Postby sha388 » Fri Jul 05, 2019 9:53 am
Thank you very much! i need to use the wrover-B since i have 3.3v.
Last question, does exist the version with higher temperatures? i saw in other datasheets, like the WROOM, that the chip could be provided with 105°C temperatures, i didn't find that info on the WROVER-B datasheet that's why i'm not sure if that version exist.
Anyway i'll ask to my contact sales also.
Thanks again!
WiFive
Postby WiFive » Sat Jul 06, 2019 4:52 am
Wrover still uses 3.3v supply and gpio
Users browsing this forum: PetalBot, Qwantbot and 2 guests
