Problem using IDF master with MDF
Posted: Mon Jul 08, 2019 2:08 pm
by willemmerson
I would like to use the most recent version of IDF inside MDF as it solves some bugs and adds some features. The version in MDF is pinned to something like IDF v3.3 which is quite old.
I updated the esp_idf submodule inside esp_mdf to master but get the following error:
xtensa-esp32-elf-gcc: error: MDF_VER="f98206c-dirty": No such file or directory
Am I doing something wrong or is it just not compatible with newer IDF versions?
Re: Problem using IDF master with MDF
Posted: Tue Jul 09, 2019 2:57 am
by LBB
Hi willemmerson,
It seems that MDF has some compatible issues with the latest toolchain, so we suggest that you can use the version included by MDF (IDF3.2) for your test to get familiar with MDF.
Also we are using IDF3.2 for our internal QA test for MDF, and for the other version of IDF, as we don't have enough test yet, there may be other issues caused by the update of IDF.
Posted: Sun Jul 14, 2019 6:32 am
by eos1d3
What I get is from IDF is v4.0-dev-1191-g138c941fa, is this stable yet?
Posted: Mon Jul 15, 2019 2:39 am
by Angus
No, this is a prerelease (development) version of IDF v4.0. The latest stable release is v3.2.2, and we're doing final testing for the v3.3 release.
Stable releases can be found here:
https://github.com/espressif/esp-idf/releases
Information about versioning can be found here:
https://docs.espressif.com/projects/esp ... sions.html
When using frameworks like MDF, it's best to use the ESP-IDF version which is bundled with MDF. In the case of the latest ESP-MDF master branch on GitHub, this is v3.2.x.
