I am not able to install EPS-IDF tools, here the dump:
aaron@aaron-crachoir:~/esp$ cd esp-idf/
aaron@aaron-crachoir:~/esp/esp-idf$ ./install.sh
Installing ESP-IDF tools
Installing tools: xtensa-esp32-elf, esp32ulp-elf, openocd-esp32
Skipping xtensa-esp32-elf@esp32-2019r1-8.2.0 (already installed)
File "/home/aaron/esp/esp-idf/tools/idf_tools.py", line 1250, in <module>
main(sys.argv[1:])
File "/home/aaron/esp/esp-idf/tools/idf_tools.py", line 1246, in main
action_func(args)
File "/home/aaron/esp/esp-idf/tools/idf_tools.py", line 1038, in action_install
assert tool_version is not None
AssertionError
could you advice?
Thanks in advance.
Problem installing IDF on linux
Re: Problem installing IDF on linux
Are you running a 32-bit (x86) version of Linux?
It seems we don't have 32-bit builds of some of the tools which are marked "required" for the installation. We will correct that.
Hello,Are you running a 32-bit (x86) version of Linux?
ESP32 IDF can't be installed on 32 bit Linux System? We are also using 64 bit Linux System and didn't try to us it into 32 but system.
Regards,
Ritesh Prajapati
Ritesh Prajapati
mishafarms
I am having this issue with a Raspberry pi 4 (still 32 bit I assume).
Any suggestions?
Michael
Any suggestions?
Michael
ESP_igrr,I am having this issue with a Raspberry pi 4 (still 32 bit I assume).
Any suggestions?
Michael
Would you please help them regarding this issue if you have any idea regarding that issue?
Regards,
Ritesh Prajapati
Ritesh Prajapati
mishafarms
I tried this all from scratch again. I had some minor issues I need to look at again with a fresh install. But everything seems to
be working now. I have a Raspberry pi 4 (4G) with an ESP32 development environment including eclipse.
Very Cool
Michael
Very Cool
Michael
Great. Thanks for update regarding that.I tried this all from scratch again. I had some minor issues I need to look at again with a fresh install. But everything seems to
Very Cool
Michael
Let me know if need any help into future for that.
Regards,
Ritesh Prajapati
Ritesh Prajapati
