how to use esp_ble_gatts_close ?
datluong
Postby datluong » Thu Jul 25, 2019 6:44 am
Hi all,
Currently, I want to terminate the connection between esp32 and mobile application by pressing a button.
How can I do that?
I have checked and then found this function:
Code: Untitled.c Select all
esp_ble_gatts_close(gatts_if, conn_id);
But I don't know how to implemet this function into my code, where can I find those two parameters, gatts_if and conn_id.
I used example code in example gatt_security_server in esp-idf folder.
Thank you very much,
chegewara
Re: how to use esp_ble_gatts_close ?
Postby chegewara » Sat Jul 27, 2019 2:34 am
When succesfully connected you will receive `ESP_GATTS_CONNECT_EVT`:
https://docs.espressif.com/projects/esp ... evt_paramE
kongon
Postby kongon » Sat Dec 19, 2020 11:01 am
You can find those values at gatts_profile_event_handler.
case ESP_GATTS_CONNECT_EVT:
spp_conn_id = p_data->connect.conn_id;
spp_gatts_if = gatts_if;
Users browsing this forum: Qwantbot, Semrush [Bot] and 3 guests
