A little help for a new guy (loop() and interrupts/tasks/something else)
theskaz
Postby theskaz » Mon Feb 13, 2017 11:26 pm
I am a .net developer playing in the IoT world. I am building a device to control some devices and read some temps. I have an ESP32, ILI9341 (using cap touch TS), Ammeter implementation, and OneWire implementation. I am using Visual Studio/Visual Micro for my IDE and its using Arduino/espressif - arduino-esp32 for compiling.
i have this code:
	if (ts.touched())
		TS_Point p = ts.getPoint();
		if ((p.x <= 100 && p.x >= 0) && (p.y <= 100 && p.y >= 0)) {
			changeStateOfBoiler();
	updateRssi();
	updateAmps();
	updateTemps();
updateTemps takes about 750ms to complete.
updateAmps() uses a millisecond counter to only actually do anything every 1 second.
void updateAmps() {
	unsigned long currentMillis = millis();
	if (currentMillis - previousAmpSampleMillis >= interval)
		previousAmpSampleMillis = currentMillis;
		double oldAmpValue = amps;
		rawAmpValue = analogRead(AMMETER_PIN);
		voltage = (rawAmpValue / 1023.0) * 5.00;
		amps = ((voltage - acsOffset) / mVperAmp);
		if (oldAmpValue != amps)
			updateAmpsDisplay(oldAmpValue);
if ts.touched() isn't getting hit for the most part. If I tap the screen repeatedly, eventually it registers and the code fires (and then locks up) so I think that im having to hit the screen in just the right time to trigger within the loop. I know that the ESP32 has 2 cores. is there a way that I can push the ts.touch() (and other items waiting for an input) to another core so that it is realtime, and the loop continues to update as needed?
theskaz
Re: A little help for a new guy (loop() and interrupts/tasks/something else)
Postby theskaz » Tue Feb 14, 2017 2:55 pm
and now that i was running a debugger and serial monitor, this is what it spits out when it locks up:
Guru Meditation Error of type LoadProhibited occurred on core 1. Exception was unhandled.
Register dump:
PC : 0x40085463 PS : 0x00060233 A0 : 0x80084940 A1 : 0x3ffdab30
A2 : 0x0000001d A3 : 0x3ffdabb4 A4 : 0x00000004 A5 : 0x3ffcb8a0
A6 : 0x3ffcb308 A7 : 0x00000000 A8 : 0x8008318c A9 : 0x3ffdab20
A10 : 0x00000003 A11 : 0x00060223 A12 : 0x00060223 A13 : 0x0000001c
A14 : 0x3ffc3dc0 A15 : 0xffffff80 SAR : 0x00000010 EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000002d LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Backtrace: 0x40085463:0x3ffdab30 0x40084940:0x3ffdab50 0x4008352f:0x3ffdab70 0x400e5591:0x3ffdabb0 0x400dddb2:0x3ffdabe0 0x400dddec:0x3ffdac00 0x4010c85f:0x3ffdac20 0x400fdb51:0x3ffdac40 0x400f823e:0x3ffdac60 0x400f8afc:0x3ffdad30 0x40096cc0:0x3ffdad50 0x4009bcfb:0x3ffdada0 0x400986f6:0x3ffdae00
CPU halted.
Hans Dorn
Postby Hans Dorn » Tue Feb 21, 2017 8:20 pm
" LoadProhibited" probably means you tried to dereference a NULL pointer.
I guess "ts.getPoint()" returned NULL when you called it.
Cheers
Hans
