ESP IoT solution library in arduino IDE
chrispal
Postby chrispal » Tue Aug 06, 2019 8:24 am
I am quite knew with ESP32 and i am coding on arduino IDE. Is it possible for me to use the esp-iot-solution library?
Thank you!
costaud
Re: ESP IoT solution library in arduino IDE
Postby costaud » Wed Aug 07, 2019 3:14 am
I think you can try using arduino as a component in esp-idf.
https://github.com/espressif/arduino-es ... mponent.md
chrispal
Postby chrispal » Wed Aug 07, 2019 6:21 am
Thank you costaud! I will give it a try!
Users browsing this forum: Amazon [Bot] and 1 guest
