undefined reference to `swap_byte_32'
redengin
Postby redengin » Wed Aug 14, 2019 6:18 am
linking is failing with the following output. Its odd, since swap_byte_32 is declared as inline in bt_defs.h. Let me know if there is a more I can do to investigate this further.
/home/redengin/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/bt/libbt.a(bta_jv_act.c.obj):(.literal.bta_jv_start_discovery_cback+0x10): undefined reference to `swap_byte_32'
/home/redengin/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/bt/libbt.a(bta_jv_act.c.obj): in function `bta_jv_start_discovery_cback':
/home/redengin/opt/esp-idf/components/bt/host/bluedroid/bta/jv/bta_jv_act.c:868: undefined reference to `swap_byte_32'
/home/redengin/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/bt/libbt.a(btc_util.c.obj):(.literal.uuid_to_string_legacy+0x4): undefined reference to `swap_byte_32'
/home/redengin/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: esp-idf/bt/libbt.a(btc_util.c.obj): in function `ntohl':
/home/redengin/opt/esp-idf/components/bt/host/bluedroid/common/include/common/bt_defs.h:112: undefined reference to `swap_byte_32'
/home/redengin/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld: /home/redengin/opt/esp-idf/components/bt/host/bluedroid/common/include/common/bt_defs.h:112: undefined reference to `swap_byte_32'
collect2: error: ld returned 1 exit status
Angus
Re: undefined reference to `swap_byte_32'
Postby Angus » Wed Aug 14, 2019 6:46 am
Hi redengin,
This should probably be declared "inline static", will fix that.
However I'm not sure this explains the error you're seeing. Can you please give some details about your IDF version, configuration, and your app project that can help us reproduce the actual linking error?
Thanks,
Angus
redengin
Postby redengin » Thu Aug 15, 2019 8:24 am
IDF: * master 39f090a Merge branch 'deprecate/spi_common_claim_macros' into 'master'
toolchain: (crosstool-NG esp32-2019r1)
I tried decorating swap_byte_32 as static but that conflicts will all the non-static inline usages.
I can't provide my project, but I can look into creating an example that has the same issue.
Angus
Postby Angus » Mon Aug 19, 2019 12:20 am
Thanks redengin.
A member of our BT team was able to reproduce this as well, and a fix should be merged to master shortly.
As a workaround the error may go away if you switch Compiler Optimisation from Release back to Debug, temporarily.
redengin
Postby redengin » Thu Aug 22, 2019 2:02 am
Using `debug` compiler optimization level does the trick for now. Let me know when it'll work with `release` level.
blueMoodBHD
Postby blueMoodBHD » Mon Sep 16, 2019 3:01 am
Hi all, This bug have been fixed, refer to https://github.com/espressif/esp-idf/co ... 9fa387a766
redengin
Postby redengin » Wed Sep 18, 2019 3:31 am
I can confirm that the latest updates have fixed this.
Users browsing this forum: Baidu [Spider] and 0 guests
