ESP-PROG pin headers
PaulVdBergh
Postby PaulVdBergh » Thu Aug 15, 2019 1:47 pm
Hi All,
I'm designing a PCB for my project. I'll use the ESP-PROG device to program/debug my design using the 1.27mm connectors. In the BOM of the ESP-PROG the connectors are described as follows :
CONN Header 5x2, DC3-简易牛角座,贴片式,1.27 mm 间距
(CONN Header 5x2, DC3-box header connector, SMT, 1.27 mm pitch)CONN Header 5x2, DC3-简易牛角座,贴片式,1.27 mm 间距
CONN Header 3x2, DC3-简易牛角座,贴片式,1.27 mm 间距 (CONN Header 3x2, DC3-box header connector, SMT, 1.27 mm pitch)CONN Header 3x2, DC3-简易牛角座,贴片式,1.27 mm 间距 (CONN Header 3x2, DC3-box header connector, SMT, 1.27 mm pitch)
Since I order all of my components at Mouser, it would be great if somebody could point me to the Mouser order numbers for this connectors. Otherwise, a link to where I can order the connectors would be great.
Thanks in advance,
Paul
boarchuz
Re: ESP-PROG pin headers
Postby boarchuz » Thu Aug 15, 2019 2:57 pm
ESHF-105-01-L-D-SM looked good on Mouser for 5x2, no 3x2 variety in that series though.
I gave up and ended up buying both from here ("Position 6" and "Position 10"): https://www.aliexpress.com/item/33020323141.html
Delivery took ~3 weeks.
PaulVdBergh
Postby PaulVdBergh » Thu Aug 15, 2019 3:25 pm
Hi boarchuz,
Thanks for your response.
AFAICS the proposed connectors at aliexpress are true-hole. I prefer to use smd-components. But if they aren't available, I'll go for your suggestion.
Perhaps Espressif could give more info re the used connectors, since they designed the ESP_PROG ?
Thanks anyway,
Paul
boarchuz
Postby boarchuz » Tue Aug 20, 2019 9:56 am
bobolink
Postby bobolink » Tue Aug 20, 2019 11:07 am
Users browsing this forum: Qwantbot, Semrush [Bot] and 4 guests
