编译esp-iot-solution的例程时候,出现如下错误:
Administrator@DE-0011 MSYS /d/lin_work/esp32_work/esp32_prj/empty_project
# make all
/d/lin_work/esp32_work/esp32_prj/esp/esp-iot-solution/submodule/esp-idf//make/project.mk:60: esp-idf build system only supports MSYS2 in "MINGW32" mode. Consult the ESP-IDF documentation for details.
WARNING: Failed to find Xtensa toolchain, may need to alter PATH or set one in the configuration menu
/d/lin_work/esp32_work/esp32_prj/esp/esp-iot-solution/submodule/esp-idf/make/project.mk:60: esp-idf build system only supports MSYS2 in "MINGW32" mode. Consult the ESP-IDF documentation for details.
WARNING: Missing submodule components/bootloader/subproject/components/micro-ecc/micro-ecc...
Attempting 'git submodule update --init components/bootloader/subproject/components/micro-ecc/micro-ecc' in esp-idf root directory...
error: 路径规格 'components/bootloader/subproject/components/micro-ecc/micro-ecc' 未匹配任何 git 已知文件
make[1]: *** [/d/lin_work/esp32_work/esp32_prj/esp/esp-iot-solution/submodule/esp-idf/make/project.mk:531:/d/lin_work/esp32_work/esp32_prj/esp/esp-iot-solution/submodule/esp-idf/components/bootloader/subproject/components/micro-ecc/micro-ecc/.git] 错误 1
make: *** [/d/lin_work/esp32_work/esp32_prj/esp/esp-iot-solution/submodule/esp-idf/components/bootloader/Makefile.projbuild:41:/d/lin_work/esp32_work/esp32_prj/empty_project/build/bootloader/bootloader.bin] 错误 2
请问这个怎么解决?
编译esp-iot-solution的例出现错误
Moderator: Bob
linyaqiang
Return to “ESP IoT Solution 中文讨论版”
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
- All times are UTC
- Top
- Delete cookies
About Us
Information
