i work just in time with a test environment ( v3.2-beta1-15-g12b2268ee )
at other place and for a simply test, i copied the base ESP-IDF components bootloader and bootloader_support
into the user project components, edit few lines in the user project component bootloader and bootloader_support folder,
i noticed then the code change in the custom code is no longer considered and the bootloader code is used from
the Base ESP-IDF-PATH components in ESP-IDF Path.
Was there are change ? Have not look into makefiles deeper yet, ( this i will do in next step, perhabs order mistake cmake/make ? )
perhabs we have a menuconfig switch for choice of src using ( my future request if we not have )
ESP-IDF-PATH bootloader src / or / Project bootloader src
i use just in time ESP-IDF version (v3.2-beta1-15-g12b2268ee)
I testet shortly then the code edit in the Base ESP-IDF-PATH Boorloader SRC, my custom code works, so i am happy that we can further customize our own bootloader code, ( no bootloader blob / lib )
for next test projects i have to edit it again in the base ESP-IDF-PATH Component,
so my question: was there a change ? i missing something? my eyes did not follow the last update comment's in ESP-IDF -
i must look deeper - so perhabs i registrate not the important change? can you point me to the change?
was the (use of components) order changed (order of success)?
is the art of custom code in the project folder no longer supported and only the Base ESP-IDF-Components are considered,
and if we want cutsomized, we must edit the components in the Base-ESP-IDF-Components ?
i am something info missing?
rudi
